Bogging problems with Silvertop 4AG (BT ECU) under 3500 RPM
06-18-2009, 10:20 PM
Re: Bogging problems with Silvertop 4AG (BT ECU) under 3500
LAC99 Wrote:from 3500 to 8000 (according to my SAFC) it worksYour engine should have a "knock" sensor, and when it detects knocking the ECU will retard the ignition timing until the knocking goes away. Then after a short time, it will put the ignition timing back to normal. I think you should check you ignition timing. It should be set at 10 BTDC with the diagnosis connector "shorted" and all accessories off. If you use low octane gas, the problem will be worse. Try and use the best gas you can get... 95 octane or better. Cheers... jondee86 |
| Messages In This Thread |
Bogging problems with Silvertop 4AG (BT ECU) under 3500 RPM - LAC99 - 06-18-2009, 01:45 AM
Re: Bogging problems with Silvertop 4AG (BT ECU) under 3500 - jondee86 - 06-18-2009 10:20 PM
| 20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 8,158 |
| No idle below 2000 rpm rich running | Steller Engineering | 3 | 3,622 |
| Question about 4AG 20v Engine Block | CHACAMAN | 1 | 3,256 |
| Big wheel problems | gh0st | 16 | 14,803 |
| Starting problems 4-AGE kouki | Hanzo | 3 | 4,800 |
