Bluetop Engine Rebuild multiple question Goal 150-160hp
04-10-2021, 07:31 PM
Hello,
i recently bought a 83 Levin with Bluetop Engine (4AGE) which i want to rebuild. My goal is to get around 150hp. And maybe ITBs in the future (mostly for the sound:loveitSmile
As i learned from my previous mistakes it's better to research first before buying anything.
I found out that there are at least 2 Bluetop Bigport versions with different pistons/compressions. Newer modells also have a smallport engine without TVIS.
9.4 : 1
10,3:1 (newer models)
10,0:1 (european modell)
Because i have an EURO Modell my engine has most likely a 10:1 compression. And Toyota can't deliver these pistons anymore.
There also different crankshafts and connection rods. The Bluetop has 40mm crankshaft and18mm connection rods.
I also found 2 really good youtube channels with a lot of 4-AGE Content.
driving 4 answers
Garage 4AGE
My questions are
1. Are the above stats correct?
2. It seems that i can reach my power goals with the bluetop engine.
Or it wise to change to smallport?
3. I also want to change oil pump, water pump etc. I read that the 20V oilpump fits on any 4 AGE. Did anybody installed a 20V oil pump?
4. I also read on the garage 4AGE channel that there are different bigport head versions. Is that true?
5. Can anyone recommend a piston sets?
6. What is the max compression for a standard ECU? I read that 10,7-10,8:1 is possible with the standard ECU.
7. Do i need aftermarket ECU for ITBs?
Thank you all in Advance.
Messages In This Thread
Bluetop Engine Rebuild multiple question Goal 150-160hp - Hanzo - 04-10-2021 07:31 PM
  Question about 4AG 20v Engine Block CHACAMAN 1 3,384 06-10-2022 05:17 PM
  Rear Differential rebuild chenfon 10 15,413 11-20-2020 12:18 AM
Last Post: totta Crolla
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 18,422 02-10-2020 06:39 PM
Last Post: Power_uP
  AE86 4A-GE 16v engine harness rebuild FanIsHere 7 15,484 01-17-2020 08:04 PM
Last Post: Project D
  Rear Caliper Rebuild mad.matt 16 22,842 01-19-2017 02:19 PM
