Best Induction Kit / Set up
06-10-2020, 10:59 AM
Hello all,
As the topic is related to filtering I will not create new one.
What do you guys use for your 20V ST/BT swapped ae86 with 100mm velocity stacks
I'm struggling to find straight forward solution.
I'm aware there is Battle garage offering their Piepercross doomed filter with backing plate.
However as I spoke to them it appears to install this kit it is essential to take off cabin heater valve which is behing the engine on bulkhead. I would like to retain this as OEM functionality for street use.
Filter they provide is C604D (PX600) which is very(too) long 435mm however have sufficient internal height 125mm to clear stacks.
Did anyone maybe tried to mount smaller version PX500 which is 370mm in lenght and 100mm internal height using so called rised backing plate to provide sufficient 19mm spacing between filter and bell mouths?
I would very much appreciate discussion in this topic.
I already saw many projects using sock filters however I'm not big fan of this solution as problems appear with sufficient flow and mounting filters to prevent them sliding down on the velocity stacks.
Best regards
Lykowsky
we ride together
we die together
  Best quality Diffs gh0st 1 2,788 07-03-2022 07:49 PM
  Rim width. Which is best.... Dino86 5 9,241 01-07-2017 03:09 PM
Last Post: Dino86
  best oil engine for 4a-geu? Mattolo 7 11,595 09-27-2011 07:44 PM
Last Post: Project D
  S2k Swap in a 86 Corolla..... What Radiator fits best !! geoscranny84 1 4,356 06-16-2010 09:40 PM
Last Post: geoscranny84
  Best Battery Amperage for the AE86 heshan 4 7,304 05-07-2009 10:08 PM
Last Post: heshan
