Battery died. Headlights now go up but not down.
09-13-2008, 03:39 AM
Hi Everyone,
I have a Trueno that was converted from a Levin. All along the headlights would pop up and go down when I use the light switch. However, a few days ago the battery died.
Because I was parked in an awkward spot I took the battery out to charge and then put it back in when fully charged. The car started and ran fine but the headlights now only pop up and do not go down.
I've checked all the fuses and they seem fine to me, but I can't figure out what's the issue. Would anyone have any ideas please?
Thank You!
09-14-2008, 12:31 PM
Sounds like a relay issue to me mate, you may want to locate the relays and give them a well needed tap.
Failing that it could be your switch. Do you have the original light switch (Levin) or the Trueno one? They have a difference between them where the Trueno one can be pushed in to keep the lights up.
09-14-2008, 04:53 PM
I'll locate the relay and give that a go. Thanks for the reply mate Smile
And I have the trueno light switch where I can push it in and go to the right once more.
09-15-2008, 01:18 PM
Maybe the retractor unit has gone bad and thinks it should popup all the time... Check the input of that unit, since it gets feed from both the lightswitch and the highbeam.
[Image: AEU86 AE86 - Battery died.  Headlights n... not down.]
  Main battery live totta Crolla 5 486 01-09-2026 11:12 PM
Last Post: totta Crolla
  Engine starts/revs but no idle GenkiMotors 17 11,997 11-20-2021 04:12 AM
Last Post: GenkiMotors
  AE86 Battery specs hachirokuGTV 9 20,290 03-13-2020 04:16 PM
Last Post: Power_uP
  LHD VS RHD headlights (Levin) Lt86 2 5,913 02-28-2017 12:08 PM
Last Post: zenki
  Carb conversion but what is this and how ? Allexz 5 10,048 05-24-2016 08:48 AM
Last Post: Allexz
