Bad gas milage
05-27-2005, 10:18 AM
Bad gas milage
Does anyone know what could be wrong? I drive approx. 9 km/ltr and it smells kinda like unburned fuel when i stop at red light (not just at red light :wink: )
I have a friend who drives 13-14 km/ltr in her Mr2, i would like that to!
05-27-2005, 11:23 AM
Bad gas milage
Hey Knudsen,
When I drive normally and mostly freeway then I also get about 13km per liter with the hachi. Once I drive in the city that drops down to around 10km per liter.
Then again, smelling gas isn't the best thing (although I have noticed that once or twice after some hard driving aswell)..
05-27-2005, 11:29 AM
Bad gas milage
Well, i havent reved mine over 4000 the last couple of weeks because of the new bearings, so i wouldnt say thats hard driving. Smile
But once again the 4AGE manual that Robokill made, has enlightend me... It could be the timing thats off, it would cause those symptoms i have Thumbs up!
05-27-2005, 12:01 PM
Bad gas milage
That's strange.
A friend of mine NEVER came below 12km per liter.
And he's not an economic driver at all.
He tried to drive fuelsafe for a few times and reached 15 km per liter with his hachi!
05-27-2005, 09:46 PM
Bad gas milage
The consumtpion falls if i use Shell v-power Racing 100 (450kms with a full tank).
Good high-reving but i have a question ...Dumb question
Is it good for the engine (because of being unleaded) or should i use Pb additives with the unleaded gasolines?
Thanks
05-28-2005, 08:30 AM
Bad gas milage
Unleaded is just fine for 4age engines alimonos..
05-28-2005, 09:27 AM
Bad gas milage
Quite a few things can be wrong! Give me a call and I'll try to help you Smile
Normally I got +12 km/l but I had two defects which ment I only got ~8 km/l Angry
[Image: AEU86 AE86 - Bad gas milage]
05-28-2005, 03:38 PM
Bad gas milage
Jan Pedersen Wrote:Quite a few things can be wrong! Give me a call and I'll try to help you Smile
It seems like i misplaced your phonenumber, Jan.... Confused
05-29-2005, 06:24 PM
Bad gas milage
I have the same problem Knudsen (at least with the smell of petrol, not so sure about mileage) and I believe it maybe a cracking pipe under the bonnet that may be leaking fumes (maybe even petrol Huh ). I really need to get it replaced but if doesnt help then I will keep an eye on this thread just in case.
05-29-2005, 06:46 PM
Bad gas milage
If you smell petrol, I would start by checking the inlet pipe, petrol nozzles and their o-rings.
BTW I hope these are the right english terms Smile
  ClutchMaxPRO Clutches - Good or Bad? RolanTHUNDER 0 2,642 12-01-2022 09:55 AM
Last Post: RolanTHUNDER
  4age hitting gas too quick means engine stalls - what is the issue? Ryo 20 37,506 06-27-2018 11:15 PM
Last Post: Ryo
  Bad vibrations /resonance starts at 5000 rpm izanagi 7 10,940 07-23-2015 05:02 PM
  bad coolant kawo 9 14,160 11-18-2013 07:43 PM
Last Post: Apsogos
  3rd door support gas springs (stay) - worn out max_ae86 5 7,947 09-01-2013 03:20 PM
Last Post: Jezza_hr
