Any one used HKS's Twin Power DLI?
06-27-2009, 07:20 PM
1 just want to know is it easy to install?
2 does he stock dli really benefit from it ? 3 or is there something better that is not complicated? this is for a ae101 4agze from HKS: ![]() The Twin Power ignition amplifier incorporates both the CDI and transistor method ignition to provide optimum spark duration and maximum voltage output, resulting in crisper throttle response and a smoother engine powerband. The CDI method, capacity discharge ignition, provides maximum voltage by transferring all stored energy in the capacitor to the ignition coil so that the ignition current can buildup quickly, thus making the Twin Power very effective in the higher revs where a normal spark would tend to diminish. This strong rapid spark prevents the high rpm ignition miss that reduces peak power. The transistorized method generates high voltage by using transistors to cut off current to the coil, thus allowing for a long energy discharge. This longer spark duration allows the Twin Power to improve lower RPM throttle response and torque. The combination of the CDI and the transistor method incorporates two distinct systems into one high performance unit, hence the designation of Twin Power. The Twin Power produces a spark output that is typically 1.5-2.5 stronger than of the stock ignition system and consumes about 35% less power input than other ignition amplifiers. Each compact and attractive Twin power unit is constructed of durable anodized aluminum and sealed to prevent corrosion from moisture. General wiring harnesses are included in each unit to aid in installation and mounting. Vehicle Specific wiring harnesses are also available for certain models to further aid in installations that require intricate integration.(CARB E.O. # D-186-29) Dimensions: All Twin Power Units, except for DLI II, are 91mm (L) x 80mm (W) x 34.5mm (H) and weighs Approximately 430g (~15.2oz) Note: HKS Twin Power Units are not compatible with Non-Resistor Spark Plugs *HKS Twin Power ignition amplifiers have been designed to work with vehicles utilizing the OEM ignition system, fuel management, Engine Control Module (ECM) or Electronic Control Unit (ECU) and with vehicles equipped with the HKS F-Con Engine Management system. HKS cannot guarantee compatibility with other aftermarket manufacturer's products. Reppin' the old skool....Drive Drift Dream ![]()
anyone?......
| Squeaky seats - any tips? | decryphe | 2 | 2,712 |
10-18-2023 10:13 PM Last Post: Power_uP |
| HKS valve springs | totta Crolla | 3 | 4,096 |
| HKS Legal exhaust | Nakilad | 2 | 6,568 |
07-31-2019 10:00 AM Last Post: Nakilad |
| HKS 260 8.0 Cam Card | d3nso | 5 | 9,129 |
02-14-2018 08:29 PM Last Post: oldeskewltoy |
| Anyone farmiliar with hks camshaft types for 4age? | spill86 | 5 | 19,819 |
11-18-2017 11:36 PM Last Post: oldeskewltoy |
![AEU86 AE86 - Any one used HKS's Twin Power DLI? [Image: AEU86 AE86 - Any one used HKS's Twin Power DLI?]](http://i39.tinypic.com/2iuxp5g.jpg)
![AEU86 AE86 - Any one used HKS's Twin Power DLI? [Image: AEU86 AE86 - Any one used HKS's Twin Power DLI?]](http://i40.tinypic.com/20itljq.jpg)
