Ae86 tacho
01-26-2017, 12:49 AM
Ae86 tacho
Hi there, on my engine swap wiring i,ve was trying to wire check engine lamp on dash and by mistake i aply 12v positive on the tacho signal dash wire. Since now my tach is dead.
How can it be fixed?
Cheers
01-26-2017, 06:21 PM
Ae86 tacho
Oh dear! I'm selling a set of clocks if that helps.
01-26-2017, 09:52 PM
Ae86 tacho
I don't know of any reason why applying 12V to the tacho input wire
would cause it to fail. But since you have done a 4AGZE DLI conversion,
you are most likely trying to get the tacho to work with the 4AGZE igniter
tacho output... and that won't drive the tacho. AFAIK the 4AGZE tacho
output is low level (5V) and the AE86 tacho needs a voltage spike (>30V)
to make it work.
You will need to either change some resistors in the tacho driver board,
or obtain a voltage spike from the negative terminal of both coils and
combine the output using diodes. You can find information for both
methods on the interweb.
Cheers... jondee86
01-27-2017, 01:31 AM
Ae86 tacho
I,ve already made the resistor things and it was working fine. I realised it doesnt work either blower fan and reverse lights so i guess its maybe a broken fuse. I will check them tomorrow.
Cheers
01-30-2017, 06:25 PM
Ae86 tacho
Finally checked all wires from both conectors and realised red and blue wire (power) was missed. I wire another power wire attached to it and everything works fine now
Funny thing is the good point to fix it was an jondee answer on another forum?
Cheers
  Tacho wiring for 20V Bentley 6 19,082 07-20-2013 11:09 AM
Last Post: fax0815
  tacho issues using haltech e6x on 4ag 20v bluehachi 5 8,252 06-05-2013 06:34 PM
Last Post: Rasteirinho
  cool tacho totta Crolla 2 4,428 03-11-2013 10:15 PM
  Tacho Signal Levin Coupe with pics Okami 10 16,053 05-31-2010 08:56 PM
  tacho signal wire totta Crolla 7 14,873 04-12-2010 09:44 PM
Last Post: Okami
