Ae86 fuel pump options
01-17-2009, 12:12 AM
jondee86
lol! Indeed Regards Lars Veiss, Denmark Currently [URL=http://www.aeu86.org/viewtopic/dk-ae86-renovation-and-turbo-project---now-driveable/t/2474/start=150[/URL] |
01-17-2009, 09:21 AM
tolisspi Wrote:i want one for external application. Which do you think to be better? Lines/hoses metallic 12mm. **COROLLA EE80 - 4AGE 124HP**
01-18-2009, 09:12 PM
The pump in the SW20 (GE/GTE) and mk4 supra will also fit.
However as said, if you dont need the fuel then dont waste your time. ![]() http://www.eight-six.co.uk - read the blog! UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk |
01-19-2009, 10:24 AM
and for a replacement pump of the 3sgte they use a.... Walbro 255lph
But for my application approx 160hm 4agze, the Walbro 255lph is to mutch ?? :S Great.. since I've got one on the shell.... Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
01-19-2009, 10:37 AM
I ordered the bosch 044 from ebay UK 153 euro (including postage). I need a big one because i run 272 10,3 cams and CR11,3:1.
01-19-2009, 11:20 AM
Gtsi-R Wrote:and for a replacement pump of the 3sgte they use a.... Walbro 255lph No its fine and will support 600bhp if you need it |
01-19-2009, 03:45 PM
is it ok for me. ll have problems like that he wrote oldeskewltoy?
01-21-2009, 05:47 PM
not sure what problems you can have... but there are 2 crucial points in the fuel system you need to check...1) fpr - what is its flow rating? Will it flow enough fuel to allow the fuel system to properly maintain pressure
2) return fuel line - what is its flow rating? Will it flow enough fuel to allow the fuel system to properly maintain pressure. If either answer to these 2 questions is no.... you'll likely get poor fuel economy, poor idle characteristics, and poor off idle throttle response. There are many options for fuel pumps besides stock(80 lph) or Walbro 255 (255 lph) Besides the GSS310 pump(rated at 115 lph), there are also 155 lph pumps, and 190 lph pumps. Do some research and fit the correct pump for YOUR needs! Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-01-2009, 05:59 AM
oldeskewltoy Wrote:BE CAREFUL!!!!!!what if you're running a silvertop 20v? (with stock injectors, 295cc) would 255 lph work in that case (walbro)? or would a 160 lph be more appropriate (tre) |
04-01-2009, 07:43 AM
shorestyle Wrote:what if you're running a silvertop 20v? (with stock injectors, 295cc) would 255 lph work in that case (walbro)? or would a 160 lph be more appropriate (tre) It'll work, it is just not the best choice. 4 - 295cc injectors will do fine on 160 lph pump Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
| Bigger brake master cylinder options | Koen Bongers | 10 | 1,326 |
01-08-2026 03:12 PM Last Post: r.ave |
| 20v BT - which oil pump? | Mylesmck | 4 | 4,790 |
| Fuel pump issue | DJexor | 11 | 8,930 |
| ITB filter options | mister86 | 1 | 4,686 |
| AE86 starter options | max_ae86 | 12 | 35,325 |
![AEU86 AE86 - Ae86 fuel pump options [Image: AEU86 AE86 - Ae86 fuel pump options]](http://i57.photobucket.com/albums/g239/N2AE86/memberbanner1jpg.jpg)
