Adjusting handbrakes (+ back up light with pictures)
05-16-2005, 02:09 PM
I have same problem with reverse light, i have a shortcircuit somewhere, have tried new switch, didn't work. didn't have time to fix yet, but you don't need for MOT/APK , not sure for RDW though.
Disclaimer: Any errors in spelling, tact, or fact are transmission errors. |
05-16-2005, 02:12 PM
The handbrake is working, thank you guys!
Now only the back up lights, I think i'm missing the cable between the lights and the gearbox. And a picture of the suspected cable. |
05-16-2005, 02:56 PM
toypower Wrote:The handbrake is working, thank you guys! not for the handbrake - these cables are not connected on my car either. K I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
05-16-2005, 03:10 PM
toypower Wrote:Now only the back up lights, I think i'm missing the cable between the lights and the gearbox. Right in the spot! I have exactly the same problem and have been discussing it with friends for some time! I checked everything else - fuses, light bulbs, boxes when i finally firgured it out - no cable! Could someone (with a present cable) take some photos and describe it. I need a raplcement!
1984 Toyota Corolla 4AGE 20v 2007 Subaru Impreza STi |
05-16-2005, 07:40 PM
cj, I made some pictures of the sensor. It's located under the car on the left side of the gearbox (small part).
I'm glad that I managed the lighting so I can travel tomorrow to the RDW to get a registration for the car. The cables are original red with a black line in it. Succes CJ! The red cable is found if you follow the engine wires. The engine wires run from near the vacuummeter |
| Can you convert your 86 back too the original state? | gh0st | 7 | 5,836 |
| Detailed LHD engine bay pictures | Bean | 0 | 4,046 |
08-05-2018 04:09 PM Last Post: Bean |
| back camber of CBY | roiz86 | 5 | 11,301 |
03-24-2013 02:00 PM Last Post: roiz86 |
| Boost Gauge help with Pictures | Okami | 42 | 49,417 |
10-17-2011 05:34 PM Last Post: Okami |
| e-brake adjusting mechanism not working! | fax0815 | 3 | 6,036 |
09-06-2011 09:16 PM Last Post: fax0815 |
