Adding O2 sensor support
01-14-2011, 07:03 PM
It seems that the O2 output from the Innovate unit may be incorrect as I'm unable to get the unit working as it should. I suspect it is all wired into the ecu correctly but the afr's are so far out according to the LM2 that the ecu thinks the O2 sensor is faulty.
This is my 2nd Innovate LM2 the 1st one was replaced under warranty this one I will have to pay for repair, it has done less than one hours work Angry
Big Grin map sensor cheating? fdsjakl890 8 3,348 08-26-2025 01:12 PM
  Radiator & grill support panel (Levin) FanIsHere 5 4,920 11-14-2022 10:07 PM
  Lambda sensor wiring sam3007 10 8,964 05-23-2022 10:00 PM
Last Post: The Doctor
  AE86 Engine Coolant Temp Sensor izanagi 8 24,400 09-06-2014 05:47 PM
Last Post: izanagi
  Hall sensor totta Crolla 7 10,799 02-28-2014 10:07 AM
