Adapters for RX-7 brake conversion
01-24-2007, 07:11 PM
Post: #31
Any chance they'll fit under 14" wheels?
01-24-2007, 07:33 PM
Post: #32
if they fit under 14ners iam in.
01-24-2007, 08:01 PM
Post: #33
From the posted link they should fit under 14" wheels..possibly a slight spacer needed if they're not very low offset 14"s.
Question is..would the fit within 13s.....hmmmm
01-24-2007, 08:04 PM
Post: #34
Jamie one set for me. Do we have a disc yet ? (RX7 / mini cooper S / Honda ???) anyone ?
01-24-2007, 08:53 PM
Post: #35
No way it's gonna fit 14"
+/-240mm = 13"
+/-260mm = 14"
+/-280mm = 15"
This spacers are made for +/-280, so 260mm honda discs are useless unless you modify the drawings.
01-24-2007, 09:05 PM
Post: #36
Ivan141 Wrote:Any chance they'll fit under 14" wheels?
I can check that for MA61 Supra rims.
IMHO 260mm disc + caliper will fit.
Quote:Jamie one set for me. Do we have a disc yet ? (RX7 / mini cooper S / Honda ???) anyone ?
Have Prelude 262mm discs laying here.
I can measure and drill the holes for caliper at the proper place (260, 280 or even different size - it's important to use the same offset only).
01-25-2007, 01:24 PM
Post: #37
jamiemirror Wrote:
Quote:What about Nissan 200sx from 1992, they use 4x114 and 280mm (if I remember correctly)
Sorry no, LarsZ. These can't fit over the AE86 front hub.
Maybe I must apologize - I found Nissan's Qinton Hazel PN#BSF4850 4-lug disc with 280mm diameter but don't know for which car yet (suspect S14 (5-lug???) and Primera P11). Will find that too :-)
I found all disc dimensions, measured AE86 hub ones and disc CAN fit over the hub. The good news is that we can use 242, 257, 280 mm no-need-to-be-redrilled discs (bone stock from the stores) with the SAME offset (i.e. one adapter with different caliper mount holes).
I can make offset calculations and build such adapter independently from Mini/Honda version.
PS: The 280mm disc is used for following models:
(note that early S13 use 252mm disc!)
Primera P11, Almera II, 200SX S13.
01-25-2007, 01:31 PM
Post: #38
Being able to adjust the disc-size according to the used wheeldiameter would be awesome..very interesting.
01-25-2007, 04:45 PM
Post: #39
I can't imaging such "adjusting" , I just talk about different choices.
In fact there is a way to create the adapter with pre-drilled holes in 3 different positions. Is this "adjusting" that you mean ?
01-25-2007, 04:49 PM
Post: #40
Jup, slap on different discs, change to other hole on adapter and ready to go.
  20v Blacktop conversion.... Mylesmck 0 1,976 04-29-2024 05:48 PM
Last Post: Mylesmck
  Kouki to Zenki Levin grill conversion? Mylesmck 6 6,414 02-08-2024 10:30 AM
Last Post: r.ave
  AFM to Map Conversion ps13michi 3 6,444 01-06-2022 10:34 AM
Last Post: ps13michi
  Sub panel and rotary-button replacement for Levin -> Trueno conversion gh0st 9 10,880 11-05-2021 08:17 PM
Last Post: gh0st
  AE86 single wiper conversion kazi 6 13,345 08-26-2017 08:47 PM
Last Post: kazi
