Adapters for RX-7 brake conversion
01-19-2007, 08:54 PM
I have the cad files for the adaptors.
http://s141.photobucket.com/albums/r69/larszylauv/
01-19-2007, 09:00 PM
LarsZ, are these files received from Hen ?
If I have the correct files - this can make entire process simple and quick (and I think - little cheaper).
01-19-2007, 09:03 PM
jamiemirror Wrote:LarsZ, are these files received from Hen ?
I dont know who made the files, I'll send you an email with the files.
01-19-2007, 09:06 PM
Thanks ! I will compare them with Hen's drawings. If these files are NOT SolidWorks ones, I can process further without waiting Hen's permission (he wrote that he can't export files in DWG/DXF format AFAIK).
01-19-2007, 09:35 PM
Jamie....no specific hurry. But if you were to fabricate them, i´d take a set of your hands.
My evil Red/Black Panda
My current JDM AE86 project
01-19-2007, 09:44 PM
Peter, already have the files (thanks to LarsZ!).
Will take a look at them, compare with drawings, have friend with RX7 FC here to test-fit - the only factor will be the time.
Will post here for progress.
01-21-2007, 07:19 PM
Hey jamie,
R.hellenbrand has them as well. But he has difrent adaptors cause he made a fit plate for it on the studs ... I have pics but have to ask him if i may post em.
When you build em I want a set as well.
01-21-2007, 07:51 PM
Quote:But he has difrent adaptors cause he made a fit plate for it on the studs
I didn't understand well that.
Another question - about material. Steel or aluminium alloy ? I see that forum member already made such adapters from aluminium but is this strong enough - your opinions ?
There is one more thing - I presume that these adapters are designed do adapt RX7 4-pots to stock AE86 brake discs. I'm planning to use different (bigger) discs on my car anyways (some Prelude ones + PCD redrill). This is impotant due to different disc offset and diameter. Just FYI.
PS: If someone else wants a set - drop me a PM or better use this thread. Will try to deliver deadline and pricing information soon.
01-21-2007, 08:08 PM
As far as i know, the kit normally includes rx-7 discs as well. Remember something about 280mm discs. They need to be drilled to fit the hachi pattern though, but i´m guessing thats minor stuff.
01-21-2007, 08:25 PM
Okay, then the adapters (shown on drawings above) are designed for RX7 discs AND calipers on AE86 strut(hub) ? Can someone confirm this ?
  20v Blacktop conversion.... Mylesmck 0 2,134 04-29-2024 05:48 PM
Last Post: Mylesmck
  Kouki to Zenki Levin grill conversion? Mylesmck 6 6,794 02-08-2024 10:30 AM
Last Post: r.ave
  AFM to Map Conversion ps13michi 3 6,727 01-06-2022 10:34 AM
Last Post: ps13michi
  Sub panel and rotary-button replacement for Levin -> Trueno conversion gh0st 9 11,623 11-05-2021 08:17 PM
Last Post: gh0st
  AE86 single wiper conversion kazi 6 13,716 08-26-2017 08:47 PM
Last Post: kazi
