APEXi SAFCII on gZe???
01-27-2006, 12:46 PM
Yes, if you have access to a laptop, then all you need is to buy the 200 dollar LC1 with lambda sensor (just the LC-1 is 150 dollars), Then you install it in place of the stock sensor, wire it in place and set the outputs up as you wish. For example in your case 1 output for narrowband simulation, and 1 for datalogging. If you have a narrowband EFR gauge you can check if the narrowband simulation is working correctly.
01-27-2006, 01:27 PM
i have a laptop! Tell me what to do for fine tuning...
What to buy and where... thanks AE86 FANATIC!!! |
01-27-2006, 02:18 PM
First have a look if your car uses a lambda sensor in the first place. If not, then you will just be using the wideband for logging (or you could use it in combination with a standalone EMS one day). Then check if you exhaust header has a bung welded into it for easy installation of the sensor. If it doesnt, you'll have to get one welded on it yourself.
Fine tuning: you also have an (S-)AFC, so the same goes for you as for nmwisima. Connect the datalogging output to your laptop, and start driving around under various conditions. There is software that you can use to analyse your data, which will tell you where to make adjustments. Then it's just a matter of repeating the process until you get the settings perfect . FABRICA MI DIEM, PVNC! |
01-27-2006, 02:51 PM
By the way..a little disclaimer is appropriate here:
AFR is NOT a good way of gaining power in a new setup..It should be approximately ok (around 1:12 to 1:13 == λ:0.7~0. ![]() A wheel to steer the front of the car A pedal to steer the rear |
01-27-2006, 03:19 PM
0,
![]() ![]() ![]() ![]() ![]() ![]() ![]() danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
01-27-2006, 04:02 PM
Where can i find this software Ivan?
Thanks a lot for your help! ![]() AE86 FANATIC!!! |
01-27-2006, 04:11 PM
Try megatune on the megasquirt forums..might not be 100% plug and play, but some hard work and sweat, typing in values by hand, could work out.
01-27-2006, 06:19 PM
I think there is also a program out there called VExme that does this kind of stuff...
DLI GZE no spark | 4agetercel | 5 | 8,070 |
02-01-2013 07:05 PM Last Post: 4agetercel |
GZE Swop with PAS & AC | Lauren | 12 | 15,745 |
02-16-2012 01:04 PM Last Post: heshan |
Engine sounds slush GZE with VIDEO ! | Okami | 13 | 16,743 |
01-03-2012 12:12 PM Last Post: Okami |
GZE swap in a SR5 | TomTom15 | 3 | 5,090 |
11-04-2011 12:30 PM Last Post: MatthewG |
GZE pulleys NEW question | Okami | 15 | 24,289 |
09-30-2011 07:08 PM Last Post: Lauren |
