AE92 injectors?
04-13-2005, 07:44 PM
AE92 injectors?
Hello,
I'm trying to improve my ae86 rallye car .
Would AE96 injectors (green connector )fit my Ae86 head? I know that the harness connectors are differents. Will the stock ECU function with these injectors ?
They seems to have a 250cc flow.
A adjustable fuel regulator , an a lighted flywheel(4,5kg) , will be the first step of my mods .(Before changing camsshafts of course)
Any advices welcome
Fil
Filh
Save the RWD cars
04-13-2005, 10:13 PM
AE92 injectors?
hi there filh
check the colour and engine code from this table:
http://www.toysport.com - tech info - toyota injectors
sorry i couldnt make a link
if they are high impedance they will run but not very well runiing lean in the top end
they could be made to work if your car has an injector resister pack (mine doesnt)
by bypassing the resistor pack so you can run high impedance injectors
[Image: AEU86 AE86 - AE92 injectors?]
if they are low impedance tell me where i can get a set as they will fit right in (as long as you change the plugs)
Run Free and take a Goodline
V8FOURCAM32 MK3 Supra
suzuki cappuccino
mondeo TD
04-13-2005, 11:53 PM
AE92 injectors?
thanks for this . I knew it but completly forgot about impedance !!
I know a place in Belgium where they only sell Toyota used parts
here it is :http://www.auto21.be/
I know they ship within Belgium , but don't know about other countries
Hope it will help
THanks
Filh
Save the RWD cars
04-14-2005, 01:00 PM
AE92 injectors?
I have a set of beige ones from AE92 GTS 4AGE engine.
13 ohm resistance, fit in rail of AE86. Also I think they are 215cc (not tested) or maybe 235cc, not 250.
04-14-2005, 01:20 PM
AE92 injectors?
Beige injectors are the same as stock ae86 injectors...I have them as well. You need the green ones for mild upgrades (if the resistance bit can be figured out.)
04-14-2005, 01:27 PM
AE92 injectors?
Ivan141 Wrote:Beige injectors are the same as stock ae86 injectors...I have them as well. You need the green ones for mild upgrades (if the resistance bit can be figured out.)
AE86 injectors are 182cc and 2.XX ohm resistance.
My beige ones are from 7-rib late-AE92 4AGE engine.
Are you sure that beige injectors are the same cc as the AE86 original ones ?
04-14-2005, 02:48 PM
AE92 injectors?
Beige ones come on ae86 and early bigport ae92 engines. 7-rib should have green injectors AFAIK...
04-14-2005, 02:52 PM
AE92 injectors?
Ivan141 Wrote:Beige ones come on ae86 and early bigport ae92 engines. 7-rib should have green injectors AFAIK...
I bought fuel rail with injectors, connection rods and crank. The seller says - 7-rib engine, the rod's big end is 42mm, the crank is 42mm too.
Hm hm hmmmm.. maybe I just need to give two different injectors for flow bench.
04-14-2005, 02:54 PM
AE92 injectors?
There are 7-rib TVIS engine's out there...with the same bigger internals as the high-compression models I believe.
05-21-2005, 10:36 PM
AE92 injectors?
again one question :
Where is the resistor plug located ?(that can be bypassing)My injectors are low impedance and those(green) I bought are 13 ohms . And if my car has no resistor pack , is there a solution to make the ae92 injectors working?
thanks
Filh
Save the RWD cars
  4AGE Injectors resistor Blaze0010 4 3,094 01-27-2025 03:20 PM
  Question about KONI shocks for an AE92 Apsogos 1 5,106 09-13-2013 07:40 AM
Last Post: Apsogos
  ae92 external thermostat housing plumbing? danny 86 2 6,216 08-15-2013 12:38 AM
Last Post: fax0815
  What injectors are these? Alex170984 4 7,398 08-05-2013 11:53 AM
Last Post: jondee86
  Annoying sound (Ae92 hatch gti) Apsogos 2 5,803 01-02-2013 12:13 PM
Last Post: Apsogos
