AE86 N2 (big update)
02-22-2009, 09:31 PM
Post: #61
And some recent pics from my last time home
[Image: AEU86 AE86 - AE86 N2 (big update)]
Recently my brother picked up a pair of Momo Rookie seats from a rally car. Waiting to be mounted when I get back.
Just need to find a pair of 3 point Sabelt harness and the leg supports for the seats.
And that's all folks!
Tongue
at least for now!
86'LEVIN Track Project
02-23-2009, 02:51 AM
Post: #62
Hey luis your car is awesome man keep up the gd work Thumbs up!
03-20-2009, 11:58 PM
Post: #63
GREAT CAR AND GRAT PICS MAN!
Really cool project!!!
Ex ITR JDM
AE86 TRUENO LOVER
03-21-2009, 04:09 AM
Post: #64
A quick update with the new parts waiting to be fitted in a couple of weeks
Tension rods and tie rods
Lower control arms
Sabelt harness
Regards :wink:
04-22-2009, 04:06 AM
Post: #65
After a short visit to Portugal I installed the new bucket seats (I still have to finish fabricating the passenger mounting brackets)
Got a new set of wheel lug nuts, which will hopefully be better and stronger than the old ones
And the suspension is now complete, finally!... Smile
Tokico HTS short stroke with Eibach 80N/mm (F) and Swift 60N/mm ®, with all the parts to coilover conversion at the front.
Everything will be assembled in June, and I can't wait for the test drive...
Regards
04-22-2009, 08:59 AM
Post: #66
Nice staff mate. You’ve probably spent a fortune for these goods. I'm looking forward to reed your feedback after the first test run. Respect!
Fun is not the straight line!
04-22-2009, 12:09 PM
Post: #67
It was bought along the past few months.
But it took me 3 years since I thought about this setup until I actually had the will power (and the economic power) to actually get it Smile
Regards
06-05-2009, 01:33 PM
Post: #68
Chassis development review...
I finally got back to Portugal for some long waited summer vacations, and the task at end was the complete assembly of the new suspension front and back.
Day 1
Rear suspension assembled. Tokico HTS and Swift 60N/m, prothane bushings to the rear swaybar and the panhard, four link and traction brakets with rose ends and ajustable lenght.
The first test run revealed much improvement, even with the same front suspension as before.
Going back to the garage and jacking the car up again. More work to follow...
And some pics...
Old rear suspension parts (good riddance my friends...)
Day 2
Disassembled front suspension. Found 2 blown out dampers... yummy!
30mm slice chopped off (to match with the 30mm spacer that will go under the damper, making up for the stoke difference to the OEM damper)
MAG welded, and with a strong linkage between the two parts.
Ready to sand and paint
At the end of day 2, this was the look of the front suspension struts.
Only the tension rod ends were being a pain in the ass to remove, so I took the chance to disassemble the compete mountings and the sway bar came with them.
Day 3
Another full day working around the suspension and the result is showing. Front coilovers finally ready!
And prothane bushings in the front sway bar
Tension rod ends mounted after some struggle with its nuts and bolts
All the fabrication was done, and the next step was to mount everything in its place.
Day 4
Early morning start and by lunch time all the suspension parts were assembled.
Then the brake disks and calipers were installed and a quick alignment was made (trusting in my "good" geometric judgment), so I could drive the car to the actual alignment shop.
After 2 hours of messing up with all the adjustments that the new suspension offers, the car was successfully aligned and all the bolts tightened and re-checked.
Suspension setup as follows.
-2,5 deg camber
-3 deg caster
0.1 deg toe out
Front track was slightly increased as well, adjusting the lower control arms. This adjustment has to be compensated in the camber plates so the camber doesn't get insanely negative.
The test run was conclusive. The car is now a breeze to drive, the control is awesome, very solid and direct. The car is less forgiving though. As long as you keep your driving within its limits everything it's excellent and predictable. But as soon as you cross that blurry boundary and the car snaps out, it does indeed SNAP out. There's no margin for error, or a really tiny one and because I'm no Ari Vatanen, it's better to be aware of this temperamental behavior of the car.
But in the end, all the work was well worth the result.
I'll try to get some better pics tomorrow.
Regards from Portugal, the upcoming AE86 capital of Europe (well, maybe not but who cares... Cool )
06-05-2009, 02:02 PM
Post: #69
Proudly Portuguese!
Sideways? Just for fun... not a way of life.
06-05-2009, 05:25 PM
Post: #70
nice
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 4,050 09-09-2022 09:07 PM
Last Post: Vaptor
  American Rally 86 UPDATE dazed_driver 136 174,090 03-28-2012 12:53 AM
Last Post: dazed_driver
  86er's Track rebuild N2.??? Finally an update page 8 86er 191 281,203 03-25-2012 10:05 AM
Last Post: bozu
  Supercharged Hachiroku "update" roadrunner 20 26,930 06-02-2011 03:27 AM
Last Post: kennedy8383
  AE86 two door 1987. in restoration, in Iceland UPDATE olithor 12 22,937 08-08-2009 12:36 PM
Last Post: rs1800
