AE86 16v standalone - any suggestions?
05-14-2007, 02:28 PM
megasquirt 3.0 can do the same as a motec. Only its difrent in tuning. Some people can modify the stock ecu creating the same idea.
I would go for MS and use a standard map (downloadable for the 4age) to start and set it 2 days on the bench for finetuning Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
05-14-2007, 02:47 PM
Just checked, Megasquirt just does the simple linear interpolation.
@Robo: It most definately does not do the same thing as motec. Whether the extra $$ is worth it depends on a lot of factors. @phatbob: know of any cheap EFI systems that do the non-linear interpolation? So far I have only seen it on the $$ systems (alongside large numbers of mappoints.) A wheel to steer the front of the car A pedal to steer the rear |
05-14-2007, 03:44 PM
This might interest you.
http://cgi.ebay.com/ebaymotors/MoTeC-M4-...enameZWDVW Is a bit more expensive (still very afforable for its price when new), but definetly a better option, if i was after one, i wouldnt think twice. ![]() Cump´s Filipe Oliveira |
05-14-2007, 04:22 PM
robokill Wrote:I would go for MS and use a standard map (downloadable for the 4age) to start and set it 2 days on the bench for finetuning Robo, have you tested this? Was the MS "stock ECU" setup really close to the stock? "..el camino's aren't supposed to make sense, craziness is what makes the world go around." - Car & Driver, 1984 |
05-14-2007, 05:36 PM
I'm just about to start this later this week, Have taken 3 days off work. I intend to fit a 36-1 trigger wheel, standard Crank position sensor, use a Perfectpower XMSL ECU, and use a peugoet coilpack. I have used this ecu on a vauxhall engine to only control ignition. But will be also controlling fuel, with my 20v ITB's. Will keep you posted on my progress, hopefully should be at the rolling road before the end of the week for a full mapping.
Ivan 1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1 |
05-14-2007, 07:49 PM
Have you looked into FJO?
Quote:FJO Racing Products releases the last engine management system you'll ever need! This product is styled after the very popular original FJO 341B System with all the features you asked for. Here is their specs sheet.... http://www.fjoracing.com/products/341B/d...%20EMS.pdf I KNOW they are less costly then 2000 euros.... but they are not cheap... but their system is better than most others!!! Here is their link on their 341B system... http://www.fjoracing.com/products/341B/ in the upper right is all the links to all the specifics... anything not there... a simple call will get you the answers... Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-14-2007, 09:49 PM
Lipinhu - That motec is nice but it cannot tune ignition map. It's only a fuel managment. For me is useless.
MS II EMS use 12x12 tune tables that means that there's 144 points for ignition and 144 for fuel. AEM EMS has 17x21. That gives at least 357 point. And You can multiply it. That's the major different between very good EMS and EMS. IF Carlsberg made an AE86, then it would be propably the best car in the world... |
05-14-2007, 11:17 PM
Quote:Lipinhu - That motec is nice but it cannot tune ignition map. It's only a fuel managment. For me is useless. Are you sure? Today i downloaded the MoTeC software for the M4 and there are igniton maps. Besides that, check on the link below for any doubts. http://www.motec.com.au/m4.htm ![]() Cump´s Filipe Oliveira |
05-14-2007, 11:39 PM
woper Wrote:MS II EMS use 12x12 tune tables that means that there's 144 points for ignition and 144 for fuel. AEM EMS has 17x21. That gives at least 357 point. And You can multiply it. Not entirely.. PhatBob is right on that one. What you are trying to do is as best as possible approximate the continuous Volumetric Efficiency map through a limited series of points. The map usually has a set of hills and vallyes that correspond to the eigen frequencies of the inlet and exhaust tract. These are pretty smooth, so approximating them through linear interpolation can be pretty rough. By using non-linear interpolation (e.g. polynomial) you can in theory get a better fit to the VE map. Obviously you need a minimum of 2 mappoints to define each hill and vallye correctly, regardless of what interpolation technique you are using.The more peaks you have and the sharper they are, the more you really need to define the VE map. Intense multiple peaks are a characteristic of well designed and executed intake and exhaust systems (4-1 ex, IRTB in). The problem becomes even bigger when you start stretching the revband. The resonant frequencies pop up in the higher rpm area's too so you need more map points again. The phenomena PhatBob describes has to do with the relative influence of the resonance peaks on the total engine throughput. They kinda get drowned out at high rpm levels, since the engine is already pumping a lot of air there. At low rpms the airflow is much smaller, so the resonant peaks are a big influence. Very hot cams produce very little airflow at these rpms, making the engine even more difficult to tune. Anyway, linear interpolation will get you all the way to a safe map if tuned by someone capable. It wont extract 100% out of your expensive engine but will comfortably do 85-90%. Those last 10-15% is where it becomes expensive. A wheel to steer the front of the car A pedal to steer the rear |
05-19-2007, 12:23 AM
thanks for good advices... I'll try to choose the best choice for my setup.
Let U know... IF Carlsberg made an AE86, then it would be propably the best car in the world... |
| Squeaky seats - any tips? | decryphe | 2 | 3,137 |
| D2 Coilovers any good? | heshan | 18 | 33,510 |
04-04-2017 02:40 AM Last Post: hachirokkos |
| ITB convert need standalone ECU | izanagi | 2 | 8,632 |
04-07-2016 11:24 PM Last Post: izanagi |
| Is this oil pump any good? | megabob | 3 | 6,823 |
02-08-2014 12:46 AM Last Post: megabob |
| 20V VVT on standalone ECU | fax0815 | 5 | 12,594 |
08-09-2013 09:27 AM Last Post: rene |
![AEU86 AE86 - AE86 16v standalone - any suggestions? [Image: AEU86 AE86 - AE86 16v standalone - any suggestions?]](http://lipinhu.no.sapo.pt/sbanner.jpg)
