AE85 vs. AE86
06-20-2007, 08:17 PM
AE85 vs. AE86
Hi.
I'm about to buy a AE85. I've read about some of the differences between the AE85 and AE86. Basicly it's the engine, the lsd? and some interiour? Can anyone here specify the differences?
I'm planning to change the engine to a 4A GZE, is this just as "simple" as changing in the AE86?
The body is the same, right? So all the styling and such is the same?
Thanks for answers. Cool
06-20-2007, 09:48 PM
AE85 vs. AE86
Are you importing the AE85 from Japan/NZ/Australia/Malaysia or are you buying a SR5 spec USDM/EU? Dumb question
For both the difference is the engine, lsd and interior, however the AE85 does have a K-50 tranny and the SR5 spec does have a T-50 tranny. For both cars you need to change the fuelpump, however you probably would need to change it anyway for a GZE swap. Wink
The body is the same, but on both SR5 and AE85 spec cars you don't have the two-tone panda color schemes. Think that's about it. Tongue
[Image: AEU86 AE86 - AE85 vs. AE86]
06-20-2007, 11:57 PM
AE85 vs. AE86
It is an AE85 from EU, Schweiz. I don't have much info about it, but the pictures are at:
http://www.need4speed.no/index.php?optio...&Itemid=34
Looks like it sais SR on the back, no 5 number (?). Is AE85 and SR5 two different cars?
The car look really good, and I'm getting a good price on it. The plan is to re-paint it anyway, to either the white/black or the red/black combination :wink:
Not sure what a K-50 or T-50 tranny is. I'm kind of a newbe, but I'll figure it out Tongue
06-21-2007, 12:01 AM
AE85 vs. AE86
banpei Wrote:The body is the same, but on both SR5 and AE85 spec cars you don't have the two-tone panda color schemes. Think that's about it. Tongue
And the brakes are dfferent; front ventilated discs, and rear discs for AE 86, and front non-ventilated discs and rear drum type for AE85.
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62
06-21-2007, 12:12 AM
AE85 vs. AE86
God I thought I knew plenty about Ae86's and stuff, I've been learning loads!
Bang her in 1st and make her Tramp
Toyota Corolla AE86 GT Rally Car
E30 BMW 318is Rally Car
06-21-2007, 12:53 AM
AE85 vs. AE86
fuel line is difrent from the rear tank and lets not forget the electronics. The ae86 almost has the same wireloom as of an GZE but the SR5 and ae85 don't.
2 thinks I find strange is that the 1.6SR is sold ineurope and second what on earth did you pay for this little car as far as i get on money it seems to be around 6000 euro's ????
06-21-2007, 07:41 AM
AE85 vs. AE86
The price on the page is not correct. I'm getting it for less than 3500 euro's. If I accept it, what do you think? Ok price for a nice car like that, remember I plan to change the engine and paint it Cool
06-21-2007, 08:59 AM
AE85 vs. AE86
well as this car is here in ZH, according to the add on mobil.de it's quite overprized... I payed about that amount for my AE86.
06-21-2007, 09:31 AM
AE85 vs. AE86
Syns Wrote:Looks like it sais SR on the back, no 5 number (?). Is AE85 and SR5 two different cars?
SR5 and AE85 are different cars. The SR5 spec has a 4AC engine (1600) instead of the 3AC engine (1500) in the AE85. It is also somewhat more luxurious in options, so it could have powersteering and airco but I doubt if that was included in the EU spec SR5.
The tranny means transmission. The K50 is, as I understood, weaker than the T50 so using a GZE on a K50 is asking for trouble. The AE86 has the T50 and we've seen several cars being converted to GZE on a T50 without major problems.
Meshin: you are right about that, I forgot to mention that as well. That also means if you swap the axle as well you have to swap the brake balancer as well.
Robokill: we have already seen a couple of SR5 spec levins through Europe: spitfire in Czech, one in Hungary and another one in Turkey. Most of them were sold in Switzerland.
You are also correct on the wireloom: the engine loom should be different but most of it is the same. Easier to swap only part of it. Wink
Syns: I think if you read this topic you can see what you're up to:
http://www.aeu86.org/index/engine-ae86-s...post=72098
06-21-2007, 10:02 AM
AE85 vs. AE86
Actually Toyota put SR5 grade only as "5-speed gear" meaning Big Grin
  Ae85 swap 4age. Minidaxman 8 10,313 04-07-2021 10:16 PM
Last Post: Minidaxman
  ae85 kickdown cable MIGGZFSU 0 4,618 05-04-2017 04:23 PM
Last Post: MIGGZFSU
  HELP! need AE85 lisse/lime cluster diagram AE86_DRIFTER_ 0 4,987 06-27-2016 11:38 PM
Last Post: AE86_DRIFTER_
  AE85 axle dif hub to ae86?? Melo 7 13,708 04-30-2012 11:38 PM
Last Post: Melo
  Approaches to making the AE85 4WD 4000GT 11 25,424 02-17-2011 10:08 PM
Last Post: jameslad
