AC problem? Idle problem?
08-18-2009, 09:37 AM
Hi ALL, I have another problem no my 86 again.
When the AC is off, everything is fine, idle steady, no problem at all. But, when I have the AC on, once I rev up the engine and let go of the pedal, the engine rev will drop very quick and sometime cause the engine goes off, any idea? I check the hose (N-port) from the throttle body connect to a small silver reservoir, but again, everything is fine. Thanks to advise!! |
08-18-2009, 05:13 PM
Sounds like your missing some kind of idle-up arrangement. If I'm not mistaken the ECU has an input for this that raises the idle when the AC kicks in. Dont ask me where to find it though.. have never seen a hachi with AC in my life.
08-19-2009, 02:08 AM
Here is 35 deg. in HK during the day. so, better have AC la.
Will try to check the idle up thingeee and hose, etc, etc, and give it a good clean, see if it can solve then....will try to do it late when have time. |
| Blacktop 20V high idle | Bravothreezero | 3 | 848 |
08-28-2026 01:11 PM Last Post: jdm86gtz |
| No idle below 2000 rpm rich running | Steller Engineering | 3 | 4,232 |
| Engine starts/revs but no idle | GenkiMotors | 17 | 14,873 |
11-20-2021 04:12 AM Last Post: GenkiMotors |
| exhaust odor/idle MOT issue | Ryo | 7 | 11,395 |
| 20v silvertop idle issue | AlexFourTwenty | 3 | 7,601 |
12-24-2017 03:27 AM Last Post: AlexFourTwenty |
