5mm headgasket
01-22-2007, 09:07 PM
5mm headgasket
hello,
I need some confirmation : I'm fitting a 5mm TRD headgasket . In workshop manual torque is set to 6,6Mkg . It's seems so low to me ! Can anyone confirm that ?If somebody has tried a higher torque , any advices and experiences welcome! Filh Filh Save the RWD cars |
01-22-2007, 11:38 PM
5mm headgasket
Those steel headgaskets usually have some pretty specific torque settings (higher than stock I believe).
You should look up TRD's specs if you can find them somewhere.. Maybe ask thomas (the Doctor) if he can take a peak in the TRD bible for you? FABRICA MI DIEM, PVNC! |
01-22-2007, 11:56 PM
5mm headgasket
Found this on TRD USA : 650cm/kg http://www.trdusa.com/partscatalog.cfm?subcategory=14 That's pretty similar to stock one . Finding that strange .... Investigating Further Filh Filh Save the RWD cars |
01-23-2007, 06:54 PM
5mm headgasket
Maybe it's because the stock headgasket is already a metal one?
01-23-2007, 07:26 PM
5mm headgasket
It need oe torque,
it´s if you use other headbolts,that it needs to be different, If you take tha oe bolts to a higher torque , you will just stretch the bolts, So oe torque, that´s what will work /Skassa Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
01-24-2007, 01:15 AM
5mm headgasket
I've finally set it to 7Mkg .hope it will last long....
As you said Ivan , I think that a metal gasket doesn't get as much distortion at tightening than a metal one . Thanks for helping Filh Filh Save the RWD cars |
01-24-2007, 02:45 AM
5mm headgasket
Just an OT; are u sure you fitted a 5mm headgasket? seems a bit thick?
01-24-2007, 02:56 AM
5mm headgasket
it will prolly be a 0.8mm or a 0.6 mm standard are 1 mm !
01-24-2007, 10:35 AM
5mm headgasket
TRD i think is 0.8 mm. DO they have 0.6 too?
01-24-2007, 03:34 PM
5mm headgasket
TRD do a 0.5. i have a 0.8 in mine but am thinking of changing to the 0.5mm
| Silvertop Headgasket? | byd1380 | 3 | 5,774 |
01-05-2009 06:02 PM Last Post: byd1380 |
| 9.5mm lift camshafts with OEM followers... anyone? | apardal | 9 | 12,349 |
10-15-2008 03:24 PM Last Post: robokill |
| head skiming/size headgasket/hks f-con! | nick | 9 | 11,766 |
04-10-2008 06:17 PM Last Post: oldeskewltoy |
| will the 0.5 mm HEADGASKET clear? | Apolan | 15 | 18,730 |
01-31-2008 01:48 PM Last Post: meshin |
| about 5mm TRD headgasket | filh | 24 | 26,404 |
04-13-2007 08:25 PM Last Post: jamiemirror |
