5.375 final drive ratio with stock T50
08-06-2012, 10:58 AM
I did consider that, and asked Leen about it, but they have not made the paddle shift yet. If its priced anything like their conversion kit, I wouldnt be interested it would be cheaper buying a sequential box!
08-06-2012, 12:25 PM
ok where does your engine make peak power and where does it drop off also how much power as well
08-06-2012, 12:34 PM
You are properbly right about the price. It is a really nice kit, though Thumbs up!
[Image: AEU86 AE86 - 5.375 final drive ratio with stock T50]
08-07-2012, 07:04 AM
Celica RA45 Wrote:ok where does your engine make peak power and where does it drop off also how much power as well
Peak power is 175WHP, at slightly over 9,000rpm (from memory on the rpm).
Jan Pedersen Wrote:You are properbly right about the price. It is a really nice kit, though Thumbs up!
Yeah I bet its an awesome kit!
On the positive note, Weir Performance have made a 5.13 final drive and will be priced under USD400. Thats a good deal.
08-07-2012, 08:12 AM
what you can do is make the ram tubes longer ,which will pick up mid range and make max power at 8500 instead of over 9
can get trd gear kit for 3k landed here in oz all the 4 gears etc
08-07-2012, 09:33 AM
The ram tubes cant physically be any longer, unless I grab a tilton or wilwood pedal box and run remote master cylinders. Really I should put money aside for a sequential box and do it properly.
08-07-2012, 09:55 AM
you can always put curved 1s on
to give you an idea
08-07-2012, 10:53 AM
I am actually running a plenum...
Here is the motor spec
Custom header (SS 304 in 1.5" diameter primaries and 660mm long, to a full 2.5" SS 304 exhaust, DEI header wrap
Custom Aluminium intake with CNC backing plate with built in 45mm velocity stacks.
3SGTE injectors
Coil On Plug ignition
Sliver top block (I grenaded a Black Top one) with balanced crank, ARP Bolts throughout, ACL bearings, Tomei rods, custom CP pistons, 15:1 CR.
288 degree 10mm lift Kelford Cams
Supertech 1mm OS valves, Supertech Valve Springs
Excedy Lightweight Flywheel
Setrab oil cooler and TRD oil filter with HKS adapter off the block
Moroso catch can (shortened to meet regs) with K&N filter
Half size radiator with alloy shrouding and electric fan
K&N 4" cone filter
TRD 0.8mm headgasket
08-07-2012, 11:49 AM
similar to group A specs
  Digital speedometer on stock dashboard FanIsHere 0 2,674 11-09-2022 01:36 PM
Last Post: FanIsHere
  T50 gearbox totta Crolla 3 4,173 02-25-2022 02:35 PM
Last Post: Project D
  82mm Stock compression Pistons apardal 4 4,541 11-24-2021 04:26 PM
Last Post: apardal
  T50 TRD gearset DidiDex 7 12,093 09-12-2019 07:36 PM
Last Post: DidiDex
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 16,964 07-18-2019 03:52 PM
