4agze question
11-09-2016, 06:55 PM
4agze question
Hi mates, im rebuilding this engine but i dont have the external thermostat housing that works on this kind of engine. The propper one is unable/impossible to locate here in Spain.
Do you know another model car what have the same type of thermo housing or another that could do the same work? Or dies anyone have one on sale? Cheers |
11-09-2016, 07:17 PM
4agze question
Why not use the OEM 16V water pump housing?
It has the thermoestat housing behind it with the water outlet.
11-09-2016, 11:24 PM
4agze question
Is it possible? On the 7rib 4agze block?
Do you have any pic of it? Cheers |
11-10-2016, 02:37 AM
(This post was last modified: 11-10-2016 02:51 AM by jondee86.)
4agze question
Two answers
![]() 1. If you are using the block without the supercharger. The 4AGZE and 16V smallport blocks are the same apart from the position of the knock sensor. If you have all the water parts from a RWD TVIS AE86 engine you can swap them directly onto the GZE block. You just need to use the RWD crank pulley, water pump and pulley (if you use the OEM fan) and the RWD alternator and bracket. I have used this setup for years and there is no problem. The only modification required is to re-route the water hard lines where they pass the knock sensor on the AE92 smallport block. If you are using a GZE block the knock sensor will be higher up and no modification will be required. 2. If you are using the block with the supercharger. I think that you will need the external thermostat setup as there is not a lot of room behind the supercharger. The GZE FWD waterlines run in behind the charger, but the remote thermostat housing lays on top of the gearbox. Be worth a look though, as the RWD hard lines lie close to the block, and it might just work Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
11-16-2016, 01:31 PM
4agze question
Hi there, thanks for the answers. Im using block with supercharger. Its very hard to find this housing, even on scrappy.
Does anyone have one of this on sale? Cheers |
11-16-2016, 10:01 PM
4agze question
Some information here...
http://www.club-k.co.nz/Forums/viewthread.php?tid=13085 ... and a lot more here... http://forums.club4ag.com/zerothread?id=90711 Maybe you can find something suitable from another FWD Corolla that you can modify to work with the GZE, Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
11-22-2016, 10:38 PM
4agze question
I finally found one from a celica. Appart fron an outlet that needs a 90degree bend the rest is straight foward from few guides on the web.
Thanks all for your answer and help Cheers |
11-23-2016, 10:54 PM
4agze question
I might have one, collected a bit of 4agze parts over the years.
11-27-2016, 01:28 PM
4agze question
Do you have injector set??
Cheers |
| 4AGZE Swap question for a AE86?? | heshan | 8 | 13,986 |
06-26-2010 11:16 AM Last Post: ash16valve |
