4agze overheating
07-22-2010, 04:26 PM
4agze overheating
Hi guys,
I'm experiencing some overheating problems with my ZE. Angry
I've took of all my waterpipes and cleaned out all the rust that was stuck in the pipes and put it back on.
I recently replaced my radiator with a new one and drove with it for more then 3 months. The car made a funny tick tick sound yesterday and when I checked the water levels there was hardly any water in the radiator. There are no water leaks whatsoever found on the car. Also my heater does not work inside the car although all the pipes are connected. Banging head
Do you think that I should replace my waterpump and flush the watersystem maybe?
or can you advise me to any solutions as to why it is still overheating?
Your suggestions and input is appreciated.
Current - 2006 Run X RSI TRD spec
Current - 1991 AE92 Conquest 4AGTE
Ex - 1992 AE92 Corolla 4AGTE(175KW&295NM)
Ex - 1983 1.8 SE Liftback(headworks and side draughts)
07-22-2010, 04:39 PM
4agze overheating
have you get all air out of the water system. Mine did leak water of head gasged.. when i pull hard then little leak. Try to put empty brake "water" botle to upside down to radiator cap.. Little tape and "screw" to plase put lots of water form cut bottom to bottle. AND start car.. THEN i only get all air from system out..
if water-pump is leaking THEN it show you must change it
07-22-2010, 04:59 PM
4agze overheating
corolla4agze Wrote:have you get all air out of the water system. Mine did leak water of head gasged.. when i pull hard then little leak. Try to put empty brake "water" botle to upside down to radiator cap.. Little tape and "screw" to plase put lots of water form cut bottom to bottle. AND start car.. THEN i only get all air from system out..
No Corolla4agze, my waterpump is all good. It's just that my car was not driving for about a month. There is no signs of a headgasket that's going and the car still idles ok...
07-22-2010, 05:59 PM
4agze overheating
Try that way to get all air of engine and sure you have put the heater to HOT, so water will go around heater core.
07-24-2010, 09:56 AM
4agze overheating
corolla4agze Wrote:Try that way to get all air of engine and sure you have put the heater to HOT, so water will go around heater core.
I found the problem corolla4agze, It was the freakin thermostat which made the clicking sound. It caused the fan switch to not go on which I thought was the switch in general but was mistaken.
Anyways thanks for the advise as I will still do what you said just to play it safe. Thumbs up!
Boost on !!!!!!!!!!
  Rear brakes overheating Blaze0010 3 1,494 10-03-2025 05:57 PM
  engine problem again overheating this time !!!! filh 11 14,988 06-08-2009 08:40 PM
Last Post: Gnugfur
  New overheating problem Ivan141 15 18,897 04-07-2007 07:15 PM
  Overheating wouter86 18 21,007 05-12-2005 09:52 AM
Last Post: robotype
