4age turbo
07-17-2009, 01:59 PM
4age turbo
what turbo shud I use with stock interns? I was thinking to buy a T20 or a T25?
wil I be needing a Additional Injector Controller?
09-02-2009, 11:34 PM
4age turbo
i have a t25 now and i am going 0.4bar with stock interns
09-02-2009, 11:43 PM
4age turbo
the T25 is the better turbo for a stock 4age Wink
it will be on full boost whene the Tvis open Wink
SR Team
BURN THE RUBER NOT YOUR SOUL!
09-03-2009, 04:19 PM
4age turbo
were do i take my oil for the turbo?
I was thinking to take out the oil pressure regulator from the oil cooler and install there the oil system. do I have sufficient pressure there? does it effect the cooling system?
09-03-2009, 06:41 PM
4age turbo
pls help... I need to finish the car in time for KOE
09-03-2009, 06:42 PM
4age turbo
I hope this will help. http://www.hachiroku.com.au/blog/?p=2285
Vladimir
[Image: AEU86 AE86 - 4age turbo]
N/A for life...
09-03-2009, 08:17 PM
4age turbo
can't find information about the oil system to the turbo.
09-03-2009, 10:29 PM
4age turbo
you can tap the hole used for the pressure sensor, just ad a T fitting and route the oil to the turbo.
09-04-2009, 12:03 AM
4age turbo
are you sure...won't there be less pressure?I mean , is there enough oil pressure for the cooler and also for turbo ? Thumbs up!
09-04-2009, 03:49 AM
4age turbo
Usualy (all the conversion post that i have read) Taked the oil for the turbo From the stock oil press sensor Wink
Whil you've add a new sensor ... the stock one became useless... Wink
SR Team
  whats the crack with 16v turbo? kazi 5 8,980 08-02-2017 12:15 AM
Last Post: kazi
  Bluetop on turbo leon205gti 7 10,900 09-20-2016 09:17 PM
Last Post: leon205gti
  can i just slam a oem turbo on it ? MC_JP 3 7,976 12-17-2014 11:04 PM
  4age stock bigport on turbo leon205gti 8 20,247 01-17-2014 01:02 PM
  4AGTE turbo manifold questions daveskatesallday 3 6,580 08-13-2013 07:38 PM
Last Post: daveskatesallday
