4age newbie having some idle issues. help!!
04-11-2010, 01:13 PM
i recently got an 85 gts and the idle was pretty high when warm like almost 2000 rpm so i lowered it a little and last night night after a little bit of hard driving my idle shot back up to 2000 rpm.my idle control screw was backed off completly. could this be the acc? i live in pr so its hot here all the time can i just eliminate it??
04-11-2010, 07:13 PM
maybe you have air in cooling system ... :wink:
04-11-2010, 08:57 PM
Or an air leak in one of the hoses that connect to the plenum.
04-11-2010, 10:06 PM
honda_what? Wrote:I live in pr so its hot here all the time can i just eliminate it??
Sure sounds like the thermostatic idle-up valve under the throttle body.
Yes, you can take it off and make up a blanking plate to bolt on in its
place. Just make sure the air ports are blocked off, and loop the two
little water hoses. Set your idle with the idle air screw, and you will just
find that your hot idle is a bit higher than your cold idle.
Cheers... jondee86
04-12-2010, 12:55 PM
Cheers... jondee86
running perfect now. jondee u r the man!!! thanks
  No idle below 2000 rpm rich running Steller Engineering 3 3,597 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Running issues sam3007 6 5,558 06-26-2022 01:34 PM
Last Post: Dave W
  Engine starts/revs but no idle GenkiMotors 17 13,719 11-20-2021 04:12 AM
Last Post: GenkiMotors
  exhaust odor/idle MOT issue Ryo 7 10,853 07-15-2019 09:17 AM
Last Post: jondee86
  Some wiring help needed DJexor 5 7,829 05-18-2019 01:50 PM
Last Post: DJexor
