4age 16v engine which is it ?
10-01-2014, 10:52 AM
hello my friends,
a good friend bought a celica but has a 4age 16v inside....We need immediately spark plug cords and a distributor cap.I dont know which exactly motor it is .....Has no tvis and it confused me...very much...help please
[Image: AEU86 AE86 - 4age 16v engine which is it ?]
4age 16v to FR 20VT
10-01-2014, 11:43 AM
That is a regular 4AGE redblack top!
NonTvis and 134bhp
10-01-2014, 01:17 PM
from AE92
10-01-2014, 02:12 PM
finally it is a non tvis but it is conversion and the cabling it is from first gen as you can see....
4age 16v to FR 20VT
10-01-2014, 02:14 PM
Converted smallport from an ae92 gt year 90-93 i think
10-01-2014, 07:52 PM
from your 2 pictures all you know for sure is... it has fwd engine mounts attached, and it has a modified smallport manifold.
It still could be a largeport with an adapter... or it could be a smallport....
one thing it isn't... is a rwd only
Dan -
10-02-2014, 03:01 PM
(10-01-2014 07:52 PM)oldeskewltoy Wrote:  from your 2 pictures all you know for sure is... it has fwd engine mounts attached, and it has a modified smallport manifold.
hello dan,
it should be the smallport finaly cause if you watch the distributor closely wou will see the small port spark cords and plastic bases among the spark pipes
4age 16v to FR 20VT
10-02-2014, 08:18 PM
It has MAP sensor and O2 or not?
My car even older than I.
Dec. 1983 zenki Levin coupe AE85 swapped to 4age16v from ae92 and other needed stuff and RHD to LHD
Nov. 1985 kouki Trueno hatchback AE85, with 86s suspension, @3A + A42DL, RHD
10-04-2014, 07:56 AM
Good morning ,it has map and it has not an o2 sensor
Sent from my SM-N9005 using Tapatalk
4age 16v to FR 20VT
10-05-2014, 10:55 AM
(10-04-2014 07:56 AM)Apsogos Wrote:  Good morning ,it has map and it has not an o2 sensor
Looking at the intake manifold it should be a smallport. But as mentioned it could have an adapter. (why would you modify an FWD intake if you don't use the normal head with it)
Easiest way to find out is take off the intake manifold. On the intake port side you can easily see if it is a smallport. Then apart from everything, they could have swaped the smallport head on an old 7 ribbed non oil squirt lower block but lets stay positive and think its an redtop 4age with oil squirters :-)
  Which Color??? oldeskewltoy 11 15,945 05-27-2014 04:22 AM
Last Post: AlexKTM
  which is the best quality flywheel brand for 4age smallport? LyndonAE86 NZ 8 15,999 12-06-2012 01:20 AM
  Velocity Stacks - Which, Where, How much? apardal 9 12,332 04-30-2008 03:38 PM
Last Post: isac
  Which brands would you be interested in for your AE86? speed-inc 27 30,066 12-12-2007 12:03 PM
Last Post: speed-inc
  Which brand wheels are these?? DJexor 1 5,252 09-16-2007 06:36 PM
Last Post: DJexor
