4AGZE Swap question for a AE86??
06-13-2010, 01:35 PM
Hi guys,
I'm planning to swap my 4AGE with a 4AGZE from a MR2..
I'm planning to go with my stock T50 gearbox and Stock Diff (with LSD).
any warnings or things to look out for??
any help would be very much appreciated guys.
Heshan.
Cheated on my いたずらな女の子 and now I can't get enough of her..
06-13-2010, 05:30 PM
you need to extend the engine harness from the 4agze
,electric radiator fan install, front mount intercooler,
modify engine mounts a little...
and when you buy a gze make sure that you have all the sensors with it
Yaris 1.3 xp9
Yaris 1.0 p1
Mercedes citan
weekend driver 1985 AE86
06-13-2010, 06:26 PM
Thanks Roger. I'm getting all the sensors..
I actually didnt realize that i had to do a electric fan conversion. hpefully the quotation my mechanic gave me has that included Sad
what about the gearbox and the diff? any changes or limitations on that?
06-13-2010, 08:08 PM
you can keep that diff stock its strong enough if you leave the engine stock
You can give it a try with the standard gearbox (I'm gonna 'do it too)
if you want a upgrade-gearbox you can use a w58 gearbox from a supra
butt remember you need a w58 to 4age bellhousing
Yaris 1.3 xp9
Yaris 1.0 p1
Mercedes citan
06-14-2010, 06:37 AM
Hi Roger,
thanks for your feedback. Actually I'm hoping to stick with the Supercharged stock engine. I won't even turbo it running @ 0.9 boost.
So i think it'll work. I'm hoping to replace my existing GB with a newer T50 GB so hopefully it'll last a bit more. My existing GB has its cogwheels all broken in to pieces and not sure why..
Thanks again Roger.. Appreciate it.
06-20-2010, 10:16 AM
What do you mean by modifying the engine mounts a little?
[Image: AEU86 AE86 - 4AGZE Swap question for a AE86??]
1987 Levin 3d - daily drifter (to be)
1990 SW20 MR2 w/ gen3 3S-GTE - daily poser
06-20-2010, 01:43 PM
the engine mount on the intake side will not fit because the supercharger He has to be adjusted
Somewhere on club4AG you will find some pics and topic
Yaris 1.3 xp9
Yaris 1.0 p1
Mercedes citan
06-26-2010, 11:16 AM
The stock gearbox will work perfectly...If you bought the engine with a clutch you will see that there is a TRD pressure plate present which you can use to replace your standard pressure plate...
Current - 2006 Run X RSI TRD spec
Current - 1991 AE92 Conquest 4AGTE
Ex - 1992 AE92 Corolla 4AGTE(175KW&295NM)
Ex - 1983 1.8 SE Liftback(headworks and side draughts)
  AE86 F20C swap - Radiator issue mad.matt 3 8,350 02-07-2018 05:14 PM
  4agze question leon205gti 8 9,794 11-27-2016 01:28 PM
Last Post: leon205gti
  AE86 w/MX-5 swap, maybe?? cke70 13 20,245 05-31-2016 08:30 PM
Last Post: cke70
  anyone swap a V6 in to a AE86? nitromadness 5 9,321 12-15-2009 01:43 PM
Last Post: nitromadness
  Write-up/How to: AE86 SR-5 to GT-S swap. ***No 56k*** assassin10000 17 34,477 09-11-2009 04:19 AM
Last Post: ae86 tn
