4AGE block differences explained (incl. some eyecandy)
02-12-2013, 05:17 PM
Post: #31
[Walaki]D`Lair Wrote:
Alex170984 Wrote:This has already mangled my melon
Is this why perhaps my other 4age seemed a hell of a lot more responsive because it had higher comp pistons in it?
Am I really going to be able to make 150+ hp with my mods with these piddly pistons in comparison to high comp?
Turbocharge the fuck out of it! Thumbs up! Thumbs up!
Nah it'd ruin the driveability of the car - supercharge yes, turbocharge no.
02-12-2013, 08:39 PM
Post: #32
That is exactly my fear too...so I bought an SR20DET Big Grin Big Grin Big Grin :mrgreen: :mrgreen: :mrgreen: :E
02-12-2013, 09:23 PM
Post: #33
Not so much candy.... but factory service manual info never the less
Rod clearances AE86 and AE92
[Image: AEU86 AE86 - 4AGE block differences expl... eyecandy)]
Rod Clearances AE111
Mains...
AE86
AE92
AE111
Dan -
02-12-2013, 11:17 PM
Post: #34
Coming along nicely, although I wasn't a big fan of club4ag still a lot of info has been lost since it crashed.
02-12-2013, 11:25 PM
Post: #35
Yes i had alot of info bookmarked there,should have saved it to the pc
I will take out the engine/crank in the weekend and take pictures then,
not possible right now.
Should lift the mystery arround hybrid 4AGE from late 1986/1987 a bit Thumbs up!
02-18-2013, 12:00 PM
Post: #36
Due to realising that I have indeed got 9.4:1 low compression pistons – I am yet to double check if I even have a 7 rib block – as I just assumed it would be!
Did the engines which these pistons were used in, run TVIS?
My TVIS did not work even though I swapped over two manifolds – it could just be a loom fault however.
Could someone clear that up for me poss?
02-18-2013, 12:10 PM
Post: #37
Alex170984 Wrote:Due to realising that I have indeed got 9.4:1 low compression pistons – I am yet to double check if I even have a 7 rib block – as I just assumed it would be!
All bigports were running TVIS. Simply put the TVIS is based on 4 parts:
the flaps with actuator, vacuum canister, vacuum hoses and trigger solenoid.
Obviously if any of those are faulty or wired/connected wrong way it won't work. Also a non TVIS ecu is a possibility.
02-18-2013, 12:28 PM
Post: #38
Its not the ECU as that is still the original supplied with my MR2.
I did swap a working tvis manifold from my old mr2 engine onto this one and it didn't work, so it must be a loom fault.
02-21-2013, 11:35 AM
Post: #39
Mercifully I do indeed have a 7-rib block!
So, if I have low comp pistons does that mean i have a low comp engine?
02-21-2013, 11:41 AM
Post: #40
the block has technically nothing to do with compression - so yes low comp pistons equal low compression Wink
  Question about 4AG 20v Engine Block CHACAMAN 1 2,317 06-10-2022 05:17 PM
  Clutch differences LUK vs Exedy r.ave 2 6,177 05-27-2021 09:30 AM
Last Post: r.ave
  BT head with ST block. CHOPKIN2 6 8,408 02-06-2018 06:27 PM
  How important are dowell pins on a 4age block spill86 5 8,859 01-13-2016 11:19 AM
Last Post: spill86
  7 rib block for a bluetop head? dinkers542 7 11,287 11-04-2014 01:44 PM
Last Post: zenki
