4AGE block differences explained (incl. some eyecandy)
02-11-2013, 04:06 PM
Alex170984 Wrote:Are they 20mm on 10.3:1 smallport and 20V pistons high comp?yes they are. I UPDATED THE FIRST POST SO READ IT AGAIN FOLKS AE86 ex-daily |
02-11-2013, 04:13 PM
Uzelac Wrote:There must be difference in height since dome is a bit bigger at HC pistons.why I said this ![]() Bean Bandit Wrote:the rest of the dimensions are the same disregarding the differences due to the dome design. AE86 ex-daily |
02-11-2013, 05:52 PM
i'll post up a picture of my new and old pistons later...
02-11-2013, 08:53 PM
Bean Bandit Wrote:I do know about it and if it had a 42mm crank then the pistons were 10.3:1 th only sub low comp (sub 10) piston with 20mm pin was the 4AGZE and they are 8.9:1 You are not right, the AE92 bigport engines with AFM came with 20mm pin 9,4:1 pistons! |
02-11-2013, 10:45 PM
Here is my old piston with a 20mm pin
Sorry about cleanliness ![]() ![]() Here is the new piston ![]() ![]() What are they? |
02-11-2013, 10:52 PM
probably AE92 bigport AFM 9,4:1 CR pistons!
02-11-2013, 10:58 PM
I haven't got an AFM
02-11-2013, 11:04 PM
ZDoman Wrote:probably AE92 bigport AFM 9,4:1 CR pistons! I stand corrected, the dish is the same as other 9.4:1 CR pistons... first time I see one of those with a 20mm pin. AE86 ex-daily |
02-11-2013, 11:07 PM
Great so i've got shit pistons
02-11-2013, 11:12 PM
wouldn't call them shit just lower compression than a smallport one
AE86 ex-daily |
Question about 4AG 20v Engine Block | CHACAMAN | 1 | 2,257 |
Clutch differences LUK vs Exedy | r.ave | 2 | 6,096 |
05-27-2021 09:30 AM Last Post: r.ave |
BT head with ST block. | CHOPKIN2 | 6 | 8,339 |
02-06-2018 06:27 PM Last Post: mad.matt |
How important are dowell pins on a 4age block | spill86 | 5 | 8,769 |
01-13-2016 11:19 AM Last Post: spill86 |
7 rib block for a bluetop head? | dinkers542 | 7 | 11,180 |
11-04-2014 01:44 PM Last Post: zenki |
