4AGE 20v ITB vacuum instructions on Intecracing.com
05-06-2011, 12:20 AM
You can take everything off except a connection at one end for the brake
booster hose and your single tapping into the common vacuum rail. The rail acts as a collector and does away with the need for a separate vacuum collector. You can dispense with the ISCV if you plan to contol idle by cracking the throttles open. Throttle opener gone, canister purge valve gone. The little air bypass screws on each throttle are for balancing purposes. Cheers... jondee86 |
05-06-2011, 09:28 PM
jondee86 Wrote:You can take everything off except a connection at one end for the brake Hey jondee can I take the main line for the vacuum manifold from the outlet where I show with an arrow in the picture above? |
05-06-2011, 11:11 PM
You can use any of the tubes that connect into the common vacuum
rail that runs across the top of the intake runners (has a screwed down cover on top). That big tube is from the ISCV... most people will use one of the smaller tubes above the ISCV tube.. The MAP signal and FPR signal like a bit of damping. You can get this by using an old in-line fuel filter, or the little round white plastic pulsation dampers used by Toyota on a lot of engines. Large hoses are not necessary on signal lines. Keep your brake booster line separate from the signal lines. Cheers... jondee96 |
05-07-2011, 12:27 AM
jondee86 Wrote:You can use any of the tubes that connect into the common vacuum Thanks for the info. Can I use the ISCV tube for the Brake Booster and use one of the two outlet above that connects to the common vacuum rail with an inline damper like show below?
05-07-2011, 03:05 AM
Quote:Can I use the ISCV tube for the Brake Booster and use one of the two Yes you can ![]() Cheers... jondee86 |
05-07-2011, 03:11 AM
jondee86 Wrote:Quote:Can I use the ISCV tube for the Brake Booster and use one of the two And what about the Blow Off Valve? |
05-07-2011, 05:50 AM
Quote:And what about the Blow Off Valve? Uses the same vacuum source as the other signal lines, so your can hook it up to one of the tubes on the common vacuum rail. That rail is connected to each throttle body via the (quite large) ISCV air inlet ports. So whatever pressure/vacuum is downstream of the throttle bodies is whatever you will read in the common vacuum rail. Of course this only applies if you are using the full 20V inlet on a 20V engine. If you have ITB's on a 16v (as I have) you need to tap each inlet port for a vacuum signal, and then average the signals in a small vacuum accumulator. Cheers... jondee86 |
| 4A-GE 20V ITB bolt patterns | kjb | 7 | 15,038 |
02-27-2016 01:23 PM Last Post: kjb |
| How to install 20V ITB on 16V head | Mr.komp | 7 | 14,959 |
12-28-2015 05:35 PM Last Post: pack |
| US-spec vacuum hard lines | LordTD | 2 | 6,600 |
04-27-2015 07:18 PM Last Post: Project D |
| VALVE ASSY, VACUUM SWITCHING, what's this for ? | Uzelac | 10 | 19,011 |
11-22-2013 10:40 PM Last Post: jondee86 |
| Machining Pistons to run 20v head... And FCR's on a 20v? | PazzaAE86 | 2 | 6,593 |
09-15-2013 01:08 AM Last Post: jondee86 |
