4AGE 16V engine overheat when at high speed
06-10-2020, 12:16 PM
RE: 4AGE 16V engine overheat when at high speed
I would first do a compression check, even if you do not have milky coolant. About the only thing left is the actual radiator. You could try a coolant flush to see if that might help. Clean the rad surface, straighten out bent fins, or find a rad shop that can rod the radiator. But you probably looking at a new rad. You can confirm insufficient Flow thru the rad, by seeing if running the heater reduces the temp. You do have an over flow tank connected in your system? I know my cooling system takes 2 or 3 short runs, then topping off the over flow tank, after cool down, to be able to get all the air out of the 4AGE cooling system.
Dave W
Messages In This Thread
RE: 4AGE 16V engine overheat when at high speed - Dave W - 06-10-2020 12:16 PM
  High-beam warning lamp Mylesmck 4 2,204 07-21-2023 07:44 AM
  Engine stress at high speeds gh0st 6 3,351 08-30-2022 07:11 PM
Last Post: Power_uP
  Cusco Powerball Headers on a NA 4AGE 16V? JDMitch 11 22,543 05-01-2021 10:09 PM
  4age 16v running roughly - diagnostics shows unknown code Ryo 8 8,674 11-09-2020 10:51 AM
Last Post: totta Crolla
  AE86 4A-GE 16v engine harness rebuild FanIsHere 7 11,549 01-17-2020 08:04 PM
Last Post: Project D
