20v throttle boddies to a 16v. what do i need
03-24-2007, 04:18 PM
as the title says. i just got an ex drifter in from japan. it has high lift cams and headwork done and an apexi AFC unit. i would like to fit the boddies to see what i could get from it and also to tidy up and minimalise the engine bay.
04-12-2007, 10:12 PM
i also have the same question if anyone has info
04-12-2007, 10:36 PM
An Adaptor plate & engine management,
Serious money boys ![]() Do a search on VEMS either here or on http://www.driftworks.co.uk An 86 is for Life, not just for Christmas |
04-12-2007, 11:22 PM
If you have an ex-drifter from japan, I would first concentrate on tidying up the engine. Japanese imports are renowned for bodged engine setups. Best make sure it actually has all the items mentioned too.
Like eircam said, an engine management is pretty much essential if you want to make, not lose, power by using ITB's. FABRICA MI DIEM, PVNC! |
04-12-2007, 11:47 PM
Ivan141 Wrote:If you have an ex-drifter from japan, I would first concentrate on tidying up the engine. Japanese imports are renowned for bodged engine setups. Best make sure it actually has all the items mentioned too.So true, the sh1t wiring thats comming in from Japan is unreal. 20v just throw-in, the fancy tuning ship jobs are no better. If you are thinking about converting to 20v ITBs its going to cost you 2000eu, alot of money in my opinion An 86 is for Life, not just for Christmas |
04-12-2007, 11:59 PM
i have a little offtopic question.. why dont people use the stock blacktop ecu when doing a full blacktop swap. why? isnt this the easiest and the cheapest solution?
04-13-2007, 09:12 AM
Apolan because is ready.
$250 for 20V ITB, $250 for adapter plate from T3, $250 for MS ECU, up to $100 for injectors and this upgrade is possible. Total ~$850 for parts + wiring, tuning etc. |
04-13-2007, 09:43 AM
Why injectors jamie? Will the stock 20V injectors not do?
04-13-2007, 10:10 AM
20v stock injectors are side feed 16v head injectors are top feed.
04-13-2007, 12:30 PM
jamiemirror Wrote:Apolan because is ready. Im sorry jamiemirror, i dont quite understand what you meant?
| How to install 20V ITB on 16V head | Mr.komp | 7 | 14,179 |
| 16V ECU pinout on 20v swap | pack | 2 | 6,989 |
06-12-2015 01:22 AM Last Post: pack |
| 20v block with 16v head and internals possible? | ditn | 3 | 8,434 |
08-12-2014 09:19 PM Last Post: ditn |
| 20v with 16v Water Relocation Kit | D.O | 9 | 18,245 |
06-12-2014 02:48 AM Last Post: jondee86 |
| Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE | Homem Bomba | 3 | 12,935 |
10-25-2013 05:13 PM Last Post: Apsogos |
