20v silvertop exhaust manifold on 16v 2nd version tvis motor
11-08-2012, 08:43 AM
Goodmorning Dan,
yes now it is feels right,at fast speeds change, i gain some rpms up..etc if from the 1st speed fast change to 2nd speed at e.g 7200rpms and before the work it falls at 5500 ,now falls eg at 5700.
Generally a better feeling at the most of rpms,seems to be work as it should work now!
yes know i can say i felt a happiness! Thumbs up!
i want your opinion about the downpipe and the oil pan, to one poing is very very close to oil pan. the pipe temperature reflects to oil pan or it warms up my oil ?
yesterday i did this work:
http://www.youtube.com/watch?v=3m-1sbsKfSc&feature=plcp
and a general photo of the downpipe position
this is not mine,but is very similar
[Image: AEU86 AE86 - 20v silvertop exhaust manif...tvis motor]
thanx
John
4age 16v to FR 20VT
11-17-2012, 05:18 PM
the complete work
http://m.youtube.com/user/apsogos4ever?f...4aAQWSu8j4
4age 16v to FR 20VT
11-17-2012, 07:13 PM
Back in 2003 I had an 1988 us-dm AE92 Corolla GT-S with its original AFM bigport 4AGE and my friend bought a front cut 20V silvertop from japan, I got the header and the 'Y' part also for free so I fit it on my AE92, I don't remember I had problems with the starter, but I remember I took it on a dyno before and after, and I got about 15nm torque everywhere so finally it was about 5hp stronger at the end. I have the dyno somewhere, I'll attach it if I find it..
11-17-2012, 07:24 PM
on the dyno plot the lower is the original, the middle is with the new header and the higher is the new header with raised ignition timing.
11-17-2012, 10:47 PM
Unbelievable great info guys!i have questions!
http://www.youtube.com/watch?v=s4aAQWSu8j4&feature=plcp
ignition set to above 10 degrees?
how many hp with the 20v header?flywheel hp?
write down numbers mate..
4age 16v to FR 20VT
11-22-2012, 08:51 PM
It was 111hp counted back to flywheel with the ignition set to 17 degrees. Sorry but I don't remember if it was with or without the shortcut in the diagnostic box..
The engine had some compression miss in the last 2 cylinders, and when I bought the car it was only 104 hp, so I was happy with that 111hp number considering these facts Smile
11-22-2012, 11:15 PM
ZDoman Wrote:[Image: AEU86 AE86 - 20v silvertop exhaust manif...tvis motor]
this dyno is with the 20v header and downpipe?
4age 16v to FR 20VT
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 6,866 05-26-2024 07:40 PM
Last Post: totta Crolla
  Smallport inlet manifold totta Crolla 6 5,231 01-17-2022 05:14 PM
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 16,859 07-18-2019 03:52 PM
  Early tvis red top from e9 gti small or bigport? Ryo 3 9,069 04-20-2018 09:14 AM
  20v silvertop idle issue AlexFourTwenty 3 6,735 12-24-2017 03:27 AM
Last Post: AlexFourTwenty
