Coilover springs free length
03-19-2007, 01:04 PM
Hi,
I found a lot of info about coil over spring rates, but ciouldn't find any about free length. I'm thinking about going for 7 kg/mm 2.5" springs but don't know what free lenght should I get. Can people with coil overs please post their specs (rate, diameter, free length, threaded sleeve length)? Any other info or advice will be appericiated too. Thanks, Avner |
03-19-2007, 01:10 PM
Get 8"-12" free length for AE86. 10" will fit best.
You can fit even 5" with custom top parts of the coilover setup, the problems start when you use 6" or shorter. |
| Rear arm length | totta Crolla | 7 | 3,771 |
06-05-2024 08:53 AM Last Post: totta Crolla |
| HKS valve springs | totta Crolla | 3 | 4,265 |
| Springs from other vehicles?? | FanIsHere | 16 | 19,680 |
05-17-2016 09:12 AM Last Post: FanIsHere |
| Driveshaft free play | thanos | 6 | 12,073 |
02-25-2015 02:10 AM Last Post: thanos |
| 4AGE 20v Ignition Lead Length | mad.matt | 3 | 8,487 |
