20v exhaust manifold, were to buy?
08-26-2008, 05:00 PM
I need an exahaust manifold for the 20v so i can use it in the corolla.
A quick search on ebay etc. tells me that all manifolds are for the fwd use of a 20v engine.
Anybody knows a reasonable priced rwd 20v exhaust manifold?
08-26-2008, 05:20 PM
Quote:EXHAUST
The factory exhaust manifold is very good with all types, both FWD & RWD, and up to about 200hp they are better than just about every aftermarket exhaust manifold available. They are a 4-2-1 design, and all types fit all the engines, with the exception of the 20v manifold, which has the two bolt holes on the extreme ends in a slightly different place to the 16v ones. But - by slotting the holes on the 16v manifolds, they can be made to fit quite easily on a 20v; usually this is done to convert a 20v to a RWD car. You'd be far better off getting things such as lightweight flywheels, etc, to improve performance, as the engine will definitely benefit from these, rather than one of dubious increase at best ...
source: http://www.billzilla.org/4agstock2.htm
So maybe you just need a normal 4AGE 16V RWD exhaust header, redrill/slot some holes and it's just bolt'n'ready.
Hope to help your search (or ease your search)
More urls:
http://home.clear.net.nz/pages/phil.brad...t%20System
http://home.clear.net.nz/pages/phil.brad...%20RWD.htm
[Image: AEU86 AE86 - 20v exhaust manifold, were to buy?]
08-27-2008, 05:29 AM
There is no need to buy a 20V exhaust slotting th eholes and using washers is fine to use.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
08-27-2008, 08:11 AM
I just found that out Smile
08-27-2008, 11:38 AM
Yes, that's right. I fitted my manifold from 4age 16V to a Blacktop 20v engine. Just had to cut one hole to make it fit
DRIFT.HR
08-29-2008, 05:33 PM
http://www.silkroad-usa.com/pages/ae86parts/header.htm
http://www.danstoy.net/products.html
08-29-2008, 06:06 PM
Nice stuff!
11-09-2010, 01:15 AM
Guys, don't slot it and use washers, it's a bodge!
here's how to cut it and reweld it properly....
http://www.elitetech.co.uk/ae86_2.htm
  Smallport inlet manifold totta Crolla 6 4,548 01-17-2022 05:14 PM
  4age blue top from MR2 same intake manifold? dinkers542 8 12,144 11-02-2014 05:24 PM
Last Post: ditn
  Machining Pistons to run 20v head... And FCR's on a 20v? PazzaAE86 2 5,834 09-15-2013 01:08 AM
Last Post: jondee86
  4AGTE turbo manifold questions daveskatesallday 3 5,594 08-13-2013 07:38 PM
Last Post: daveskatesallday
  Were to find 4AG-ZE gaskets in toyota diy? fax0815 17 18,506 05-28-2013 10:17 PM
Last Post: ditn
