20v Blacktop conversion....
04-29-2024, 05:48 PM
(This post was last modified: 04-29-2024 05:49 PM by Mylesmck.)
Hi Folks,
My 4age rebuild is nearing completion, and again I'm after some help What do people usually do about the engine - gearbox brackets? there's 2 mounting holes on each side of the block for them, one of which is now used for the engine mounting brackets in rwd configuration. Are these brackets required? If so, would it be ok to cut them down to one bolt to the block and two bolts to the bellhousing on each side? Also, Valve lash caps, is it ok to sand these down using some fine (1000 GRIT) paper? They're quite tight following on from a little valve lapping, and the smallest size from Toyota is 1.70mm Thanks |
| Blacktop 20V high idle | Bravothreezero | 0 | 66 |
08-08-2026 10:49 AM Last Post: Bravothreezero |
| Refreshed 20v blacktop first start.. | Mylesmck | 6 | 3,564 |
| Kouki to Zenki Levin grill conversion? | Mylesmck | 6 | 6,060 |
| Improve 20V Blacktop cooling | pack | 0 | 2,351 |
06-07-2023 01:18 PM Last Post: pack |
| AFM to Map Conversion | ps13michi | 3 | 6,241 |
