20v BT valves choice
05-20-2019, 02:26 PM
Hi everyone,
I'm doing a rebuild of my 20v BT.
My next step is to buy new valves.
As I already got TODA spring, what valves would you recommend with that valve spring ? Stock valves, Supertech valves (has been told they are noisy), Ferrea valves or other brand ??
I'm still running stock camshaft too.
Thanks for your help.
05-20-2019, 04:09 PM
(05-20-2019 02:26 PM)izanagi Wrote:  Hi everyone,
Why do you want new valves??
unless your plans include building this for substantially more power, stick with the OEM valves (known quality).
Dan -
05-20-2019, 05:08 PM
Because after checking the size of the valve stem (according to the FSM), mine doesn't reach the size recommended. They are thinner.
05-20-2019, 06:32 PM
I agree with what's already been said, stick with OEM valves. I've never known there to be anything wrong with the original valves for any application so far, especially if you're running stock cams.
05-21-2019, 08:21 AM
Should I buy new OEM valves ?
05-21-2019, 04:42 PM
Stem and guide "work" together..... the same FSM lists maximum valve/guide clearance. I'd recommend using that before you condemn the valves.
Exhaust valve - 0.1mm (.0039")
Intake valve - 0.08mm (.0031")
If they still are too small..... the choice is yours... replacing OEM valves, with OEM can get pricey, or you go oversize with Supertech....
As to Supertech... OEM valves the intake stem is larger, but with the Supertech the exhaust stem is larger........ not sure why that is....
Dan -
05-21-2019, 04:59 PM
(05-21-2019 04:42 PM)oldeskewltoy Wrote:  Stem and guide "work" together..... the same FSM lists maximum valve/guide clearance. I'd recommend using that before you condemn the valves.
I'm gonna check and let you know. Thank you very much for your help.
05-21-2019, 10:52 PM (This post was last modified: 05-22-2019 12:03 AM by izanagi.)
After checking every valve stem, they are all between 4.92 and 4.93 mm. Inside valve guide is 5 mm.
05-22-2019, 01:30 AM (This post was last modified: 05-22-2019 01:31 AM by oldeskewltoy.)
sounds like you are no more then .08mm.... as long as valve margins are within spec ...it's your call, but I'd likely re-assemble with new seals and call it good.
Dan -
05-22-2019, 08:47 AM
I have new seals. Thank you so much for the advice.
  16V Valves.... oldeskewltoy 15 24,774 10-04-2022 01:20 PM
Last Post: corolla4agze
  Valves identification FanIsHere 1 4,647 10-29-2020 06:18 PM
  Machining Pistons to run 20v head... And FCR's on a 20v? PazzaAE86 2 6,949 09-15-2013 01:08 AM
Last Post: jondee86
  need help with tire choice Jango_Fett 3 6,107 07-07-2009 10:44 PM
Last Post: Jango_Fett
  Ticking valves jos 4 age 9 12,586 06-28-2008 08:42 AM
Last Post: jos 4 age
