20V Blacktop oil pressure?
11-26-2010, 10:38 PM
what is the oil pressure for a blacktop 20v?
cold en hot oil temp.
i have a TRD oilfilter en castrol 10W40 oil. my presure is cold 6.2 bar.
and hot around 3.2 bar. 1800 RPM. is this normal?
toyota corolla coupe 1985 drift car
toyota corolla coupe 1987 road car.
11-27-2010, 11:59 AM
My oil pressure with 5W50 oil is 2-2.5 bar at idle, so i guess its normal Big Grin
AE86 GT - SR20DET BlackTop //// Trackday beater
Citroen C4 Coupe VTR - 1.6HDi //// Streetcar
11-28-2010, 06:10 AM
slowboy2 Wrote:...presure is cold 6.2 bar.
That is higher then it should be if the gauge is accurate. Has anyone stuck a shim in the oil pump relief valve? I hope it isn't going any higher then that when it's cold & revved up! Huh
11-28-2010, 12:08 PM
when it is cold and i rev it up it go to 7 bar.
when it is hot it wil go to max 6 bar.
idle cold is 6.2 and idle hot is 3.2
first it was cold 5.5 bar en hot 3 bar idle. and max 6 bar reving.
i have cleaned the sensor for the vvti. is this the problem?
where can i find the oil pump relief valve?
11-29-2010, 09:42 AM
slowboy2 Wrote:when it is cold and i rev it up it go to 7 bar.
You've got an optimistic gauge or a valve someone has F'd with. Your losing some HP from the extra/useless pressure it's putting out and and have a chance of popping the filter or breaking the pump.
I don't understand 'first', first what, before the vvti sensor thing?
Valve is on the pump body.
11-29-2010, 08:58 PM
i have cleaned the sensor in front of the exhaust manifold.
[Image: AEU86 AE86 - 20V Blacktop oil pressure?]
and after that i get more oil presure.
my engine is also very dirty.
can this be the problem?
this foto is from a year ago.
11-29-2010, 09:39 PM
Looks like a stereotypical 'low mileage' + low maintenance 20v.
Caked oil crust everywhere. Isnt there a temp sensor in the head that's related to this issue in blacktops? My friend had one and told me about it, but he sold the car a long time ago already.
12-03-2010, 08:52 PM
thanks. i wil look at the oil pump asap.
my oil pressure is now about 7 bar cold. but it is cold here. Tongue
at ivan141: bedoel je toevallig de koelvloeistof sensor achter in de kop. bij het thermostaat huis? er zitten daar 3 sensoren 1 voor de airco. 1 voor de temp sensor voor dashboard en 1 voor de computer. welke kan dan het probleem geven?
sorry that it is not in english.
12-03-2010, 09:30 PM
Dunno to be honest.. just something I overheard. Many engines have the sensor in the back of the cyl.head.
The caked oil is a direct result of the combination: high engine temp, not enough oil changes. 20v's require more frequent oil changes due to the high temps.
  Refreshed 20v blacktop first start.. Mylesmck 6 2,429 10-07-2024 07:55 AM
  20v Blacktop conversion.... Mylesmck 0 1,214 04-29-2024 05:48 PM
Last Post: Mylesmck
  Improve 20V Blacktop cooling pack 0 1,765 06-07-2023 01:18 PM
Last Post: pack
  20v BT - which oil pump? Mylesmck 4 4,487 06-21-2022 04:51 PM
Last Post: pack
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 24,259 08-19-2018 12:08 PM
Last Post: AlexKTM
