1986 Corolla SR5 S2k Build.... MIami style
08-26-2010, 06:37 AM
Wassup Folks...
Me and my father in law has beeen working on this project... he bought the car about 6months ago... just shell. From there we slowly got S2k parts... -Motor is a 2006... we knew it was drive by wire > SOoo i thought all that was needed was a TB... NO. NO NO.. LOL We had to change the complete mani + TB, valve cover + cam sensors,04 engine harness+ ecu, crank sensor + crank teeth sensor > we went over all to a 2004 !! -Trans is a > 2005 > Stock clutch for now.. - 2 peice drive shaft - GTS gas tank - wire tuck - Stock S2k ecu 04 -3 inch exhaust + Vibrant tip -JSP engine Mount kit : ) -Radiator got Custom fitted + water necks turned by CAKES FAB !! We are also running a S2k cluster.. + s2k dash harness........ : ) wiring has been a mish but almost done... Car starts now .... just have 3 bugs to get rid of.... I got alot of pics to come........... START UP VID !! > http://www.youtube.com/watch?v=3wYGEx8rS_A When we got her !! ![]() Motor... ![]() Trans..... ![]() Steering spline "extended" ![]() OIL pan ... cut n welded cause it was touching > Subframe !! ![]() ![]() ![]() Subfram... cut and welded !! ![]() Test fit..... did this like 6 times !! .. just to make sure we had enough clearance in the tunnel of the tranny... ![]() Strip down and cover a few holes... then PAINT !!! ![]() ![]() ![]() ![]() ![]() 3 Inch FTW... ![]() ![]() Griffin Rad... With Custom work done to it by CAKES FAB !! !! DOG POWER !! ![]() ![]()
08-26-2010, 07:56 AM
is that a std. rear axle? you might want to change that for something stronger
08-26-2010, 05:54 PM
Probably need celica/supra rear.
08-28-2010, 01:33 PM
meh, the t series??? can last well if looked after. and lsd choice is important. josh young ran a tseries behind his turbo 4age for i think 3 drift seasons and it never broke.
but driving style has a lot to do with longevity ![]() looks great man, how much did you have to space the crossmember down to fit it all in? clutch kick, switch, tree .... oowwww |
09-23-2010, 07:18 PM
09-27-2010, 09:50 AM
I like your style! ;-)
09-27-2010, 05:43 PM
love that conversion
10-21-2010, 05:48 PM
thanks......^^
10-21-2010, 09:41 PM
any pics of how the oilpan clears the subframe and the gearbox clears the tunnel tunnel now?
http://monkeymagic86.wordpress.com |
10-22-2010, 04:33 PM
s2k + ae is ideal combo, sadly i can't ftw..
so fucking expensive engine here ( congrats owau no ka "I" |
| 1986 Toyota Corolla Levin 2dr GT-Apex | ondafly | 24 | 1,959 |
02-11-2026 03:49 PM Last Post: ondafly |
| (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 5,374 |
| OST-050 - a VERY special build | oldeskewltoy | 49 | 48,475 |
01-05-2019 07:03 PM Last Post: oldeskewltoy |
| d3nso's little AE86 N2 build | d3nso | 27 | 42,443 |
11-13-2017 11:42 AM Last Post: mad.matt |
| Beams Levin build | mannix20vt | 5 | 11,621 |
![AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style [Image: AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style]](http://i76.photobucket.com/albums/j30/geoscranny/corolla%20S2k%20build/IMG00097-20100602-1713.jpg)
![AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style [Image: AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style]](http://i76.photobucket.com/albums/j30/geoscranny/corolla%20S2k%20build/IMG00100-20100603-1721.jpg)
![AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style [Image: AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style]](http://i76.photobucket.com/albums/j30/geoscranny/corolla%20S2k%20build/IMG00127-20100613-1451.jpg)
![AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style [Image: AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style]](http://i76.photobucket.com/albums/j30/geoscranny/corolla%20S2k%20build/IMG00122-20100608-1330.jpg)
![AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style [Image: AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style]](http://i76.photobucket.com/albums/j30/geoscranny/corolla%20S2k%20build/IMG00131-20100615-1812.jpg)
![AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style [Image: AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style]](http://i76.photobucket.com/albums/j30/geoscranny/corolla%20S2k%20build/IMG00133-20100615-1813.jpg)
![AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style [Image: AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style]](http://i76.photobucket.com/albums/j30/geoscranny/corolla%20S2k%20build/IMG00135-20100615-1947.jpg)
![AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style [Image: AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style]](http://i76.photobucket.com/albums/j30/geoscranny/corolla%20S2k%20build/IMG00126-20100613-1450.jpg)
![AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style [Image: AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style]](http://i76.photobucket.com/albums/j30/geoscranny/corolla%20S2k%20build/IMG00147-20100619-1127.jpg)
![AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style [Image: AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style]](http://i76.photobucket.com/albums/j30/geoscranny/corolla%20S2k%20build/IMG00150-20100619-1654.jpg)
![AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style [Image: AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style]](http://i76.photobucket.com/albums/j30/geoscranny/corolla%20S2k%20build/IMG00157-20100623-2002.jpg)
![AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style [Image: AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style]](http://i76.photobucket.com/albums/j30/geoscranny/corolla%20S2k%20build/IMG00189-20100701-2016.jpg)
![AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style [Image: AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style]](http://i76.photobucket.com/albums/j30/geoscranny/corolla%20S2k%20build/IMG00203-20100706-1942.jpg)
![AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style [Image: AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style]](http://i76.photobucket.com/albums/j30/geoscranny/34946_426707204512_512244512_442102.jpg)
![AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style [Image: AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style]](http://i76.photobucket.com/albums/j30/geoscranny/corolla%20S2k%20build/IMG00277-20100821-0812.jpg)
![AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style [Image: AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style]](http://i76.photobucket.com/albums/j30/geoscranny/corolla%20S2k%20build/IMG00278-20100821-0944.jpg)
![AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style [Image: AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style]](http://i76.photobucket.com/albums/j30/geoscranny/corolla%20S2k%20build/IMG00281-20100821-1250.jpg)
![AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style [Image: AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style]](http://i76.photobucket.com/albums/j30/geoscranny/corolla%20S2k%20build/IMG00284-20100821-1437.jpg)
![AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style [Image: AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style]](http://i76.photobucket.com/albums/j30/geoscranny/corolla%20S2k%20build/IMG00308-20100904-18592.jpg)
