1986 Corolla SR5 S2k Build.... MIami style
08-26-2010, 06:37 AM
Wassup Folks...
Me and my father in law has beeen working on this project... he bought the car about 6months ago... just shell. From there we slowly got S2k parts...
-Motor is a 2006... we knew it was drive by wire > SOoo i thought all that was needed was a TB... NO. NO NO.. LOL We had to change the complete mani + TB, valve cover + cam sensors,04 engine harness+ ecu, crank sensor + crank teeth sensor > we went over all to a 2004 !!
-Trans is a > 2005 > Stock clutch for now..
- 2 peice drive shaft
- GTS gas tank
- wire tuck
- Stock S2k ecu 04
-3 inch exhaust + Vibrant tip
-JSP engine Mount kit : )
-Radiator got Custom fitted + water necks turned by CAKES FAB !!
We are also running a S2k cluster.. + s2k dash harness........ : ) wiring has been a mish but almost done...
Car starts now .... just have 3 bugs to get rid of....
I got alot of pics to come...........
START UP VID !! > http://www.youtube.com/watch?v=3wYGEx8rS_A
When we got her !!
[Image: AEU86 AE86 - 1986 Corolla SR5 S2k Build.... MIami style]
Motor...
Trans.....
Steering spline "extended"
OIL pan ... cut n welded cause it was touching > Subframe !!
Subfram... cut and welded !!
Test fit..... did this like 6 times !! .. just to make sure we had enough clearance in the tunnel of the tranny...
Strip down and cover a few holes... then PAINT !!!
3 Inch FTW...
Griffin Rad... With Custom work done to it by CAKES FAB !!
!! DOG POWER !!
08-26-2010, 07:56 AM
is that a std. rear axle? you might want to change that for something stronger Smile
08-26-2010, 05:54 PM
Probably need celica/supra rear.
08-28-2010, 01:33 PM
meh, the t series??? can last well if looked after. and lsd choice is important. josh young ran a tseries behind his turbo 4age for i think 3 drift seasons and it never broke.
but driving style has a lot to do with longevity Smile
looks great man, how much did you have to space the crossmember down to fit it all in?
clutch kick, switch, tree .... oowwww
09-23-2010, 07:18 PM
09-27-2010, 09:50 AM
I like your style! ;-)
09-27-2010, 05:43 PM
love that conversion
10-21-2010, 05:48 PM
thanks......^^
10-21-2010, 09:41 PM
any pics of how the oilpan clears the subframe and the gearbox clears the tunnel tunnel now?
http://monkeymagic86.wordpress.com
10-22-2010, 04:33 PM
s2k + ae is ideal combo, sadly i can't ftw..
so fucking expensive engine here (
congrats
owau no ka "I"
  1986 Toyota Corolla Levin 2dr GT-Apex ondafly 43 6,122 05-14-2026 02:45 PM
Last Post: ondafly
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 5,812 09-09-2022 09:07 PM
Last Post: Vaptor
  OST-050 - a VERY special build oldeskewltoy 49 50,732 01-05-2019 07:03 PM
Last Post: oldeskewltoy
  d3nso's little AE86 N2 build d3nso 27 43,781 11-13-2017 11:42 AM
  Beams Levin build mannix20vt 5 11,968 01-27-2016 12:39 AM
Last Post: mannix20vt
