14x7 Celica Supra wheels and spacers?
03-09-2011, 01:18 AM
14x7 Celica Supra wheels and rear spacers?
What size spacer do I need in the back to fit my wheels resonably flush or a tiny bit poked? I have 195/55-14's on there now, so there is an ever-so-slight stretch, but definitely not square fitment. |
03-09-2011, 01:42 AM
I beleive they will fit out of the box, no spacers needed.
03-09-2011, 07:30 AM
I know they will, but they're sunk in... which is why I said I wnted a flush or slightly poke fitment. That's gonna mean using a spacer but I don't want to go TOO big.
03-09-2011, 09:09 AM
They seat flush alright.
The offset is 8, so 5 mm plain spacer will take you to +3 which is fine. A. danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end http://www.jdmbits.com
03-09-2011, 07:27 PM
Ahhh I see the offset is +8. Now that I know this, I think I'll actually go with an 8mm spacer and give myself -/+0, having seen what zero offset and 7" wide looks like on these cars. Thanks for the info!
03-09-2011, 09:29 PM
Arro Wrote:Ahhh I see the offset is +8. Now that I know this, I think I'll actually go with an 8mm spacer and give myself -/+0, having seen what zero offset and 7" wide looks like on these cars. Thanks for the info! You cant do that! You either go with 5 mm plain spacer which allows the nuts to bolt properly, or then move up to 10 mm with their own studs. They are more expensive though. A. danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end http://www.jdmbits.com
03-09-2011, 10:16 PM
Here are some pics from my car with 185/60/14 fitted in celica supra rims:
without spacers: ![]() ![]() with 25mm spacers: ![]()
03-10-2011, 10:42 AM
nmwisima: I would have run longer studs
Don't think I'll go that route now...Rosedrift: I assume those 25mm spacers are hub-centric pieces w/ their own studs and short inner nuts to go on the factory studs... also I assume you had to grind down the factory studs to clear the wheels... right? Your fitment is exactly what I want! |
03-10-2011, 12:34 PM
YES hubcentric with their own studs, and NO i didn't had to grind down the factory studs.That's why I went to 25mm, with 20mm you'll probably need it. The only thing I had to do is to bend a little the fenders from inside to avoid the contact with tyres.
I bought my spacers from pass racing (california)
| 4age fuel rail spacers | kpretro84 | 5 | 9,524 |
03-16-2013 08:30 PM Last Post: Bean |
| celica ra40 brake upgrade | geoffersmaher | 8 | 11,704 |
12-21-2009 10:52 PM Last Post: geoffersmaher |
| 4AGE ECU CELICA-CARINA-CORONA COUPE | tolisspi | 11 | 14,124 |
01-10-2009 09:39 PM Last Post: banpei |
| just bought sum celica supras an im on a budget need tires?? | truebluegallo | 4 | 5,780 |
10-28-2008 10:21 PM Last Post: banpei |
| DIY: My Celica-Supra (MA45/46/47) diff swap & info. | assassin10000 | 17 | 30,784 |
07-15-2008 11:47 PM Last Post: assassin10000 |
![AEU86 AE86 - 14x7 Celica Supra wheels and spacers? [Image: AEU86 AE86 - 14x7 Celica Supra wheels and spacers?]](http://img713.imageshack.us/img713/6573/deigma.jpg)
![AEU86 AE86 - 14x7 Celica Supra wheels and spacers? [Image: AEU86 AE86 - 14x7 Celica Supra wheels and spacers?]](http://img6.imageshack.us/img6/8096/fghpg.jpg)
![AEU86 AE86 - 14x7 Celica Supra wheels and spacers? [Image: AEU86 AE86 - 14x7 Celica Supra wheels and spacers?]](http://img696.imageshack.us/img696/893/cimg0108y.jpg)
![AEU86 AE86 - 14x7 Celica Supra wheels and spacers? [Image: AEU86 AE86 - 14x7 Celica Supra wheels and spacers?]](http://img23.imageshack.us/img23/2503/dfdfnv.jpg)
![AEU86 AE86 - 14x7 Celica Supra wheels and spacers? [Image: AEU86 AE86 - 14x7 Celica Supra wheels and spacers?]](http://img862.imageshack.us/img862/7753/67589811.jpg)
