trans oil, lsd oil change
06-10-2005, 06:01 AM
You might want to open up the fill plug before you open the drainplug. Nothing sucks more than opening up the drainplug, only to find the fill plug stuck on really bad.
To fill the transmission without using a pump, you can take out the shifter and pour in 1.7L through the shifter hole. I usually slightly overfill by putting in 2 quarts of MTL or MT90 (1.9L won't hurt anything, and helps assure lubrication of the input bearing) HTH. |
Messages In This Thread |
trans oil, lsd oil change - Apolan - 06-03-2005, 08:30 AM
RE: trans oil, lsd oil change - mad.matt - 10-01-2014, 03:57 PM
[] - jamiemirror - 06-03-2005, 10:01 AM
[] - jamiemirror - 06-06-2005, 03:30 PM
[] - Brian - 06-10-2005 06:01 AM
Oil cooler -> low oil pressure | Jan Pedersen | 24 | 32,762 |
06-06-2013 07:36 PM Last Post: Deuce Cam |
Change the meter between zenki and kouki | T_AE86 | 9 | 11,207 |
12-03-2012 03:13 PM Last Post: T_AE86 |
More positive gear change | phill 92 | 12 | 13,054 |
05-21-2012 10:51 PM Last Post: phill 92 |
LSD Oil, Necessary? | phill 92 | 6 | 9,036 |
04-06-2012 05:17 PM Last Post: Sgonzalez |
what clutch for a W58 trans to a 4AGE Blacktop? | slowboy2 | 17 | 25,913 |
11-17-2011 08:36 PM Last Post: slowboy2 |
