starting/electrical issues
12-11-2013, 03:29 AM
To be fair, throwing bigger cable at it is not the best way to solve this
problem. The important thing is the total resistance for the circuits...
battery positive to starter, and engine block to battery negative. That
plus the cranking amps will determine the voltage drop while cranking.
As you have stated, there are plenty of 4Ga installs that work fine. So
if your starter is in good condition and your battery is fully charged,
check the voltage at the starter while cranking. If you have 10V or
better, the 4Ga is not the problem.
Then you need to check that you are getting a full 12V at the COR
while cranking. If there is a bad (high resistance) connection on the
keyswitch power supply, or a high resistance ground, the voltage may
drop low enough during cranking to prevent starting.
Cheers... jondee86
Messages In This Thread
starting/electrical issues - Jezza_hr - 12-10-2013, 01:13 AM
[] - pack - 12-10-2013, 01:39 AM
[] - Jezza_hr - 12-10-2013, 01:51 AM
[] - pack - 12-10-2013, 02:25 AM
[] - allencr - 12-10-2013, 04:54 AM
[] - jondee86 - 12-10-2013, 08:23 AM
[] - Ivan141 - 12-10-2013, 09:59 AM
[] - Jezza_hr - 12-10-2013, 12:52 PM
[] - Jezza_hr - 12-10-2013, 09:51 PM
[] - jondee86 - 12-11-2013 03:29 AM
Re: starting/electrical issues - allencr - 12-11-2013, 09:21 AM
[] - Jezza_hr - 12-11-2013, 11:19 AM
[] - Jezza_hr - 12-14-2013, 02:37 PM
[] - jondee86 - 12-15-2013, 02:03 AM
[] - Apsogos - 12-21-2013, 05:45 PM
  Running issues sam3007 6 6,109 06-26-2022 01:34 PM
Last Post: Dave W
  lntermittent starting totta Crolla 6 6,979 08-31-2021 06:21 PM
Last Post: totta Crolla
  Starting problems 4-AGE kouki Hanzo 3 5,138 08-31-2021 06:20 PM
  Over heating issues MIGGZFSU 12 17,517 05-11-2017 05:09 PM
Last Post: MIGGZFSU
  JDM trueno not starting. need help! kazi 8 12,947 03-12-2017 05:05 PM
Last Post: kazi
