starting/electrical issues
12-10-2013, 09:59 AM
About the tach signal converter: I assume the Omex item needs a 12v+ and gnd connection, same as the ones I built myself from time to time. If it drops you are probably experiencing voltage dips on the supply circuit when switching on other electronics.
The way those boosters work is they use 12v to charge a coil, and a transistor (driven by your low voltage tach signal) to break the coils ground circuit. That creates big voltage peaks at the output. If for some reason your coil does not get enough voltage to charge, the produced voltage spike may not be high enough to register on your cluster.
Another cause could be jitter on the tach signal, causing it to switch too fast..
Messages In This Thread
starting/electrical issues - Jezza_hr - 12-10-2013, 01:13 AM
[] - pack - 12-10-2013, 01:39 AM
[] - Jezza_hr - 12-10-2013, 01:51 AM
[] - pack - 12-10-2013, 02:25 AM
[] - allencr - 12-10-2013, 04:54 AM
[] - jondee86 - 12-10-2013, 08:23 AM
[] - Ivan141 - 12-10-2013 09:59 AM
[] - Jezza_hr - 12-10-2013, 12:52 PM
[] - Jezza_hr - 12-10-2013, 09:51 PM
[] - jondee86 - 12-11-2013, 03:29 AM
Re: starting/electrical issues - allencr - 12-11-2013, 09:21 AM
[] - Jezza_hr - 12-11-2013, 11:19 AM
[] - Jezza_hr - 12-14-2013, 02:37 PM
[] - jondee86 - 12-15-2013, 02:03 AM
[] - Apsogos - 12-21-2013, 05:45 PM
  Running issues sam3007 6 6,109 06-26-2022 01:34 PM
Last Post: Dave W
  lntermittent starting totta Crolla 6 6,979 08-31-2021 06:21 PM
Last Post: totta Crolla
  Starting problems 4-AGE kouki Hanzo 3 5,138 08-31-2021 06:20 PM
  Over heating issues MIGGZFSU 12 17,517 05-11-2017 05:09 PM
Last Post: MIGGZFSU
  JDM trueno not starting. need help! kazi 8 12,947 03-12-2017 05:05 PM
Last Post: kazi
