starting/electrical issues
12-10-2013, 04:54 AM
How're the starter solenoid's contacts?
It doesn't need extra grounds or anything special, it only needs adequately sized wires, equal to or a little larger then original, with good connectors/terminals and good contact between them on everything you've done and on all the original wiring, that's it if the starter hasn't been burned up by now. It Does Not need a ground cable from the battery all the way from the battery in back to the block in front!! Millions of steel chassis/frames already do that very well. Yours is not an exception. |
| Messages In This Thread |
starting/electrical issues - Jezza_hr - 12-10-2013, 01:13 AM
[] - allencr - 12-10-2013 04:54 AM
Re: starting/electrical issues - allencr - 12-11-2013, 09:21 AM
| Running issues | sam3007 | 6 | 6,109 |
| lntermittent starting | totta Crolla | 6 | 6,979 |
08-31-2021 06:21 PM Last Post: totta Crolla |
| Starting problems 4-AGE kouki | Hanzo | 3 | 5,138 |
| Over heating issues | MIGGZFSU | 12 | 17,517 |
| JDM trueno not starting. need help! | kazi | 8 | 12,947 |
