rear wheel bearings
10-06-2006, 02:35 AM
rear wheel bearings
is here a diferance between the 1984 rear wheel bearings, and cars from 1985 onwards?
seen bearings advertised for 1985/87 but nothing for the 1984
is there a differance or do they fit all years?
10-06-2006, 09:03 AM
rear wheel bearings
Zenki (early model) and Kouki (late model) halfshafts have different splines because the kouki models are slightly thicker, but I'm not sure if that translates to different bearings. It could very well be....
10-06-2006, 09:08 AM
rear wheel bearings
nah the wheel bearings are the same as far as I know
The only problem is disc brake rears and drum brake rears are different bearings (drums are hella cheaper! Hurray! )
Thumbs up!
[Image: AEU86 AE86 - rear wheel bearings]
10-06-2006, 01:04 PM
rear wheel bearings
All ae86s (1983-1987) with rear disk brakes use the same halfshaft bearing size. As oli said above, be careful not to buy the "drum" type. They are cheaper indeed, but are not the correct ones.
check this topic: http://www.aeu86.org/viewtopic.php?t=3371&highlight=
1984 Toyota Corolla 4AGE 20v
2007 Subaru Impreza STi
  Spare wheel & spare wheel carrier ondafly 6 2,219 01-19-2026 01:00 PM
Last Post: ondafly
  Question on Rod Bearings mister86 3 6,452 03-19-2020 03:46 AM
  Emergency help find store with bearings france Allexz 5 7,795 09-12-2019 03:24 PM
Last Post: Allexz
  Diff bearings izanagi 11 21,507 07-05-2014 07:29 PM
Last Post: assassin10000
  Top mount bearings totta Crolla 1 5,252 01-22-2014 11:33 AM
Last Post: totta Crolla
