few issues after last drift days, advice needed
08-26-2011, 08:33 AM
Re: few issues after last drift days, advice needed
fax0815 Wrote:-the freshly rebuild diff started to make noises and i found axial play
on the pinion shaft, will dissasemble to check whats the problem...
If you are using the OEM crush tube for pre-loading the pinion bearings,
it is likely that the crush tube has been compressed due to the high loads
generated by drifting techniques. If this has happened, you will need to
replace the OEM crush tube with a solid spacer and shims.
Cheers... jondee86
Messages In This Thread
[] - BOOMEX - 08-26-2011, 03:53 AM
Re: few issues after last drift days, advice needed - jondee86 - 08-26-2011 08:33 AM
  PWR light issue and no brake fluid after winter storage magpie 10 7,136 05-25-2023 08:09 AM
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 3,854 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  Running issues sam3007 6 5,510 06-26-2022 01:34 PM
Last Post: Dave W
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 10,268 07-31-2019 11:28 AM
  Brake advice - master cylinder mannix20vt 12 19,236 08-21-2017 03:21 PM
Last Post: Project D
