clutch slave cylinder leak
06-12-2010, 12:08 PM
Brings back memories of doing this on Banpeis car (if I remember correctly).
Was an easy as job, new slave costs only a few bucks.. Some good tips there hell ride, we took the easier route by just replacing it and bleeding it (so yes, the "need an assistant" option you mentioned, but good tip on filling the slave up with fluids first so you don't need to go nuts bleeding the air out. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
Messages In This Thread |
clutch slave cylinder leak - Shane - 04-09-2010, 01:06 AM
[] - Mux213 - 06-12-2010 12:08 PM
4AGE cylinder head plug removal | Ivan141 | 5 | 2,650 |
Brake advice - master cylinder | mannix20vt | 12 | 15,401 |
Correct connection brake master cylinder? | bozu | 5 | 7,837 |
torque setting head cylinder bolts | izanagi | 1 | 5,289 |
05-29-2015 01:23 AM Last Post: oldeskewltoy |
Dimensions clutch master cylinder | bozu | 2 | 6,555 |
04-16-2015 07:11 AM Last Post: bozu |
