clutch replacement
09-03-2006, 11:28 AM
Dude... you seriously need to download the tech manuals! Will help you not get stuck with these problems.
You need to remove the propshaft, then unbolt the bellhousing from the engine (make sure the tranny is supported, some people tie a rope around it from inside the car.. might be an idea). Also dont forget to unhook the slave cilinder and speedo drive. Once all is loose you can pull the gearbox back and out, exposing the clutch so you can work on it. FABRICA MI DIEM, PVNC! |
| Messages In This Thread |
clutch replacement - surfingdrums - 09-03-2006, 09:04 AM
[] - Ivan141 - 09-03-2006 11:28 AM
[] - surfingdrums - 09-03-2006, 05:23 PM
[] - surfingdrums - 09-08-2006, 10:37 PM
[] - surfingdrums - 09-15-2006, 08:58 AM
| Engine mount replacement - tips/tricks ? | ondafly | 4 | 756 |
02-24-2026 12:34 PM Last Post: ondafly |
| Exhaust replacement | banpei | 35 | 14,852 |
10-24-2024 10:45 AM Last Post: decryphe |
| Sub panel and rotary-button replacement for Levin -> Trueno conversion | gh0st | 9 | 9,224 |
11-05-2021 08:17 PM Last Post: gh0st |
| Catalytic converter replacement | Ryo | 5 | 10,733 |
06-10-2015 09:38 PM Last Post: KoJl6ACA |
| Coilover shock replacement | phill 92 | 9 | 14,269 |
08-28-2012 08:46 PM Last Post: phill 92 |
