bigport to smallport install
09-26-2012, 03:40 PM
Hello,
I am interested in installing the smallport 4age into my ae86 so doing some reading on how people have done this. I have a few questions that i'd appreciate some advise on. One issue i have come across is the inlet manifold. The smallport (non t-VIS) engine is a FWD application and so the inlet manifold points the opposite way to the RWD T-VIS version. This needs remedying to complete a successful install! One solution i have seen is to use the RWD inlet manifold but remove the T-VIS from the RWD 4age inlet and install the T3 bigport to small port adapter (https://technotoytuning.com/toyota/16v4a...rt-adapter) The other method i have seen is to cut'n'shut the FWD non T-VIS inlet to work the other way round so the throttle body etc. does not point towards the firewall. Does anyone have advise on advantages/disadvantages of both options? Of course i could go ITB, but thats a project for another day! At the moment i wish to keep stock ECU. Presumably if keeping a stock ECU i would need to use the smallport one rather than bigport? Would the smallport ECU give me any problems with the loom/electrics for my ae86? Thank for any input. James PLAY.FIDDLE>LEARN |
| Messages In This Thread |
bigport to smallport install - sketchy - 09-26-2012 03:40 PM
[] - totta Crolla - 09-26-2012, 06:27 PM
[] - oldeskewltoy - 09-26-2012, 09:07 PM
[] - totta Crolla - 09-28-2012, 10:24 AM
| Smallport coil | totta Crolla | 2 | 3,584 |
08-12-2022 11:03 AM Last Post: totta Crolla |
| Smallport inlet manifold | totta Crolla | 6 | 5,819 |
01-17-2022 05:14 PM Last Post: oldeskewltoy |
| Early tvis red top from e9 gti small or bigport? | Ryo | 3 | 9,551 |
| 10.8:1, 264/256° Bigport | nyberrg | 4 | 8,650 |
06-12-2017 09:57 AM Last Post: nyberrg |
| 4A-GTE 7-rib smallport | nyberrg | 5 | 8,791 |
05-24-2017 09:24 PM Last Post: krullibull |
