Which Daihatsu parts are compatible?
10-14-2005, 07:41 PM
they should be cheaper,but as for ring and pinion gear u could try one from the automatic carina,cause they would have difretn gearing to the manual ones
10-14-2005, 08:14 PM
Ivan: great idea!
10-14-2005, 08:26 PM
mr monster Wrote:i would try and see about that cause i know for sure the dont carry rear sway bars and the earlier models had leaf springs,but for the size of the rear end it may be the same as the sr which i think is 6.3 and not the gts which is 6.7 but im not too sure i only know that the gts carry 10 bolts to hold the diff housing so thats all i have to go on,but i found out that the rear end on a carina cant remember which model is a 10 bolt 6.7 like the gts and can hold a zenki lsd but will have to get the sway bar brackets welded on
wait a minute...
same size as AE86 but leafsprings?
Are you sure? because that could maybe be the solution to my KE20 (and also Damir's KE25) problems....
10-14-2005, 08:51 PM
You would probably still have a problem because the placement of the leafblade mounts is too wide for a ke20. The old celica/carina axle is pretty good I think, since ae86 pumpkins will fit in it.. There are places that sell leaf-spring mounts tat you can weld onto the axle yourself, otherwise it might be possible to take them from an other car all together (there are plenty with leafsprings out there, and the system is pretty much the same on all of them).
Ring and pinions would only be interesting in 4.3 and shorter ratio's.
4.1's can be found quite cheap from Richmond gears, who make them for a small racing class in the US (Legend cars, they use an old toyota axle).
210 dollars or something....But I dont need a 4.1 , I already have a good 4.1 in my basement.
11-25-2005, 06:36 PM
What are the wheel meaturements on a charmant? 4x114.3 as well?
[Image: AEU86 AE86 - Which Daihatsu parts are compatible?]
11-25-2005, 06:38 PM
i think so yes
11-25-2005, 06:56 PM
Apolan Wrote:i think so yes
Nice...
I found one quite cheap. Would be nice to use it during the winter and then use the spares for my hachi. Smile
11-26-2005, 12:10 AM
There is an engine builder here in holland that has built a 2liter 4age head engine using a daihatsu rocky bottom end....weird shit...he was talking about using a 2.5 rocky block for his next build Huh
11-26-2005, 01:44 PM
kinda like b20a cr-vtec conversion on hondas.. whats the bottom end like on hose engines? r/s ratio? for a cr-vtec conversion it is neccessary to sleeve the cylinders, or it will break. but those blocks are cast iron right. will that hold?
  20v BT - which oil pump? Mylesmck 4 5,191 06-21-2022 04:51 PM
Last Post: pack
  Rim width. Which is best.... Dino86 5 9,065 01-07-2017 03:09 PM
Last Post: Dino86
  which connector is this ditn 7 10,461 07-27-2015 11:24 AM
Last Post: pack
  Haslbeck front spoiler, which foglights? wouter86 2 6,646 02-15-2015 11:14 AM
Last Post: ditn
  which piston is this? ditn 10 15,311 07-04-2014 03:18 PM
